Philips Magnavox Learning Universal Remote Logo
Posted on Oct 12, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have no ''tv/catv'' button on my Philips universal remote
I have a White-Westinghouse TV-VCR combo, model WVT-11911, and I replaced my lost remote with a Philips Universal Remote, model SRU3003WM/17. The TV setting for TV/CATV is set to antenna and I need to set it to CATV in order to see more than 19 channels. The universal remote has no ''TV/CATV button as did the original remote. What do I need to do?
Lawrence Oravetz
Level 3:
  • Philips Master 10,558 Answers
  • Posted on Oct 12, 2017
Lawrence Oravetz
Philips Master
Level 3:
Answers
10558
Questions
Helped
2700237
Points
29284
You can go here to see if you can get a new factory remote
TV Parts Universal TV Stands DLP Chips ShopJimmy or you can get a Harmony remote that will never go obsolete no matter how many times you change Tv's in the future or add components to your system
3 Related Answers
Anonymous
  • 57 Answers
  • Posted on Feb 13, 2009
SOURCE: Have Philips universal remote--need code for ESA vcr/dvd combo
Here you go. Follow this link: for code 0287
http://www.urc.philips.com/find_baseCode.asp
I hope this solution is helpful. Pleaseremember to rate this solution.
Anonymous
  • 23 Answers
  • Posted on Apr 25, 2009
SOURCE: CODES FOR SRU3003WM/17 REMOTE
try this website "www.remotes.com"
Kerry Degrand
  • 112 Answers
  • Posted on Jul 15, 2009
SOURCE: CODE LIST FOR SRU3003WM/17 FOR TOSHIBA TV
these are the codes for toshiba try all to find best one
0517, 0419, 0512, 0613, 0719, 0112, 0506, 0111, 0618, 0627, 0437, 0041, 0094, 0802, 0111, 0313, 0715
1helpful
Philips Z11 TV/VCR Combo. I need the 4 digit universal remote code for TV VCR please.
I don't think you will get that to work, you have two units in one box
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
'Z11' doesn't seem to be the correct alpha numerical model number.
https://www.google.com/search?q=philips+z11+tv%2Fvcr+replacement+remote
Save Code list for future reference Refer to the setup ...
Philips https://www.p4c.philips.com > files > sru4000_17 PDF Save Code list for future reference Refer to the setup procedure below and look up the 3 digit code for your brand of TV, VCR, etc., from the list below.
2 pages
Missing: z11 ‎' Must include: z11
Philips 4 digit remote codes for Combo devices - eliztech.com
eliztech.com https://www.eliztech.com > remotes > philips-4digit-co...
Four digit code lists for HTIB and TV/VCR/DVD/DVR/SAT/CABLE Combos - Philips universal remote controls.
Philips Universal Remote Control Programming Instructions
directutor.com https://www.directutor.com > content > philips-sru210...
Program your audio and video devices with Philips Universal remote codes, simple steps for programming Philips universal remote...
2answers
I need code for philip s remote for a sayno ty
Philips rca universal remote codes sayno vcr dvd combo ...
www.fixya.com > ... > Remote Controls
Universal Philips Magnavox remote for a Sanyodvd vcr combo ? I have a cableremote and need to program my Magnavox vcr/dvd combo into it i have 2 dvds ...
How to Reprogram a Philips Universal Remote Controller ...
science.opposingviews.com > Computers
7helpful
3answers
I lost my remote codes for my philips US2-PM435S
Lost my remote codes for my philips remote. I need the combo codes for a tv, vcr,and dvd.
13helpful
5answers
Admiral tv/vcr, innovage jumbo remote
YOU CAN USE EMERSON CODES FOR YOUR ADMIRAL TV AND TV / VCR COMBOS, MY COMCAST REMOTE ACCEPTED 11911. SOME REMOTES NEED FIVE NUMBERS AND MY ADMIRAL ONLY HAS THREE. SO I USED AN EMERSON CODE AND IT WORKED MOST OF THE BELLS, NOT ALL WHISTLES WORKED BUT I DIDN'T HAVE TO GET UP TO TURN IT ON, CHANGE THE CHANNEL OR THE VOLUME. MY KIDS WON'T DO IT ANY MORE!!
GOOD LUCK!!!!!
3helpful
4answers
WHITE-WESTINGHOUSE TV/VCR COMBO NEED CODE
The code for the TV is 0623 but to use the TV/VCR button to change mode from line to TV the code is one of the following 0179, 0451, 0463, 0624 or 0278. The 0623 only activates the menu but doesn´t let you change Air/Cable mode without first changing the Line/TV mode by pressing the TV/VCR or Line input button on your universalk remote with one of the other codes.
1helpful
Remote lost: My TV/VCR Combo only displays 12 channels
Go to http://www.jvcremotes.com/ or any similar site and order the original remote. That way you are sure to get a remote capable of doing whatever you need. The alternative is to keep buying universals until you get lucky and find one that works all functions on that set.
4helpful
How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.98fe8a9.jpg
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
