Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
Anonymous Posted on Aug 22, 2007
Hotpoint FDW60 problem
Hi there, I have a problem with a 2yr old Hotpoint FDW60. At the beginning of a cycle it will start to fill with water and then go quiet, which I presume is the water heating. Then, from the back of the machine we here a gurgling sound - it is like steam escaping. This just continues until we switch it off. If I open the machine there is water in the bottom and it is hot. Any ideas where I look next? There are no error codes on the front. Many thanks Nobby Clarke
A
Anonymous
Hi there, Spot on - the wash motor was seized. Unfortunately running the dishwasher like this meant the heater was on with no water, so it overheated and melted loads of wires and the black stuff on teh underside of the tub. Ah well, thanks anyway. Nobby
Anonymous
Level 2:
  • Expert 183 Answers
  • Posted on Aug 31, 2007
Anonymous
Expert
Level 2:
Answers
183
Questions
0
Helped
102425
Points
278
Wash motor either seized up/ faulty or the is an itme jamming up the impeller. Regards Advisor
Won't wash
If this happens within the first. 9 secs after filling it means you have a hearing fault
My Hfdw80 dishwasher wont start.There is a motor winding noise but no water?Hotpoint
Hi First you have to check the water valve to see if it has power during the time it should be filling the washer , Set the unit to fill and wash you know where it normally starts filling with water , remove the two wires from the water valve and check to see if you have power going to the valve , you have to eleminate things to find out what the problem is , if you have power then check to see if you have water to the valve, if you have water and you have power but you arent getting water then the water valve is bad , and this will be a cheep easy fix , have a good day
FDW60 has standing water in the bottom and will not fill up
You most likely have a stubborn clog in your kitchen drain. Try filling the sinks with warm soapy water and then letting the water drain while also turning on your garbage disposal. Sometimes the extra water pressure will help push the clog through.
11helpful
2answers
Hotpoint FDW60 flashing eco light
if the eco light is flashing, this indicates that saftey float switch has activated in the base of the dishwasher usually caused by a leak, a polystyrene float activates a microswitch which cuts of the water inlet supply
2helpful
2answers
Fdw60 starts but stops soon after
In my case it was the pressure sensor on the side of the short hose between the main (circulatory) pump and the bottom jet arm (which spins inside the machine)
Remove it and test resistance on terminals while blowing into the tube.
There is another pressure sensor on a hose attached to the waste assembly but appeared to be working correctly.
Hotpoint Dishwasher not working - FDW60
unplug it for an hour this normally fixes this problem on my machine
Hotpoint fdw60 trips consumer unit when switch the plug switch
Hi i have hotpoint FDW60 when i swich the plug and the dishwasher starts then you hear the dishwasher filling up it trips my electric in the house.
1helpful
Error lights.
This is a Circuit Board that is bad (main control).Do not repair this because the problem returns,and returns.
3answers
Empties and fills but boils the water
Can you hear/see any washing sound/spray, it sounds to me like the wash pump could be faulty.
It's Leaking Water!
Most common reason is that the lower spray arm splits on the seem and sprays water under the door, to proove if it is this remove lower spray arm and run through program if no leak fit new arm. Regards Advisor
Top Hotpoint Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
