Question about Boating
Cummins qsd 2.0 150
Hi I have a QSD 150 that has just had a new ECU and Turbo fitted under warranty. Hoever now sometime it just wont rev over 3000RPM other time it is fine. In addition the sterndrive trim only works at low revs and will not work at high revs. When the Engine hrs were 180 but since the new ECU are now 6hrs. Thank for your help.
    Sergeant:
  • 331 Answers
I think you should go back to your dealer to fix those problems. The original problem isn't solved totally with the done replacements.
Working yourself on the engine could void your warranty!
Posted on Nov 15, 2017
6ya staff
SOURCE:
Anonymous
  • 129 Answers
SOURCE: rev counter
The revs were reset wrong, get them re adjusted. Go back to same garage and ask for it to be done free, as it was done wrong first time.
Posted on Jul 18, 2008
keemo68
Ronald Mueller
  • 1263 Answers
SOURCE: diesel turbo with no power at low revs
this tells me that the injector timing is off just a bit or you may have a weak injector all together.
Posted on Sep 05, 2008
Anonymous
SOURCE: I have a Renault Megane
Have you tried the idle control valve, these can stick & cause the engine to rev high. Have had this problem on a few cars, a Vectra being the worst, but quick clean with brake cleaner & good as new.
Posted on Jan 16, 2009
Anonymous
SOURCE: jaguar x300 no pulse at injectors replaced ecu, what else could i
does it have a spark at the spark plug leads? if no it sounds like the crank shaft sensor!!
Posted on Apr 05, 2009
Anonymous
  • 133 Answers
SOURCE: when im idling in park or neutral engine revs high
These cars used a motor underneath the intake manifold to control the idle. The crank sensor may need to be checked, the signal to the motor needs to be checked. If you have a seperate control module (passenger footwell, right side, behind the plastic) under the main fuel control module, you may want to check the wiring on that as well. The Haynes manual for these vehicles describe the system very well.
Posted on Nov 03, 2009
Engine management light is on, and wont rev very high, any ideas please ?
It is in limp mode and requires servicing at a deatership to have the ECU reset.
Nov 22, 2014 | Cars & Trucks
How do I wire a mb quart QXD 164 crossover to a kef kar kx3?
I would not recommend this.
Crossovers are designed with specific speakers in mind - they are not interchangeable, since the impedance (Resistance and Inductance) varies widely.
While this will not damage anything to try it, it will probably sound terrible as most people that have separates for the car audio are fairly particular about sound.
May 14, 2014 | MB Quart QSD 164 Car Subwoofer
My 2001 laguna 1.9dci is loosing power going up hills.Buzzing sou
Have seen the turbo solenoid valves go faulty but these models are also bad for airflow meters.Any fault codes?
Apr 07, 2010 | 2001 Renault Sportwagon
Not sure what kind of oil to put in my 1988 f350 diesal?
XO-15W40-QSD 6.9L/7.3L/6.0L As low as 10 degrees Fahrenheit
XO-10W30-QSD 6.9L/7.3L/6.0L As low as -10 degrees Fahrenheit
Motorcraft Oil
Dec 04, 2009 | 1988 Ford F 350
Charging problem on 1996 Dodge Ram 3500 Cummins Turbo Diesel
I had the same problem on a 94 dodge with the cummins. It seems the crank sensor that reads from a notch on the harmonic balancer was the problem Without this sensor reading that the engine is running the alternator wont charge. Possibly the same problem with yours
Mar 25, 2009 | 1996 Dodge Ram 3500 Club Cab
Boating Logo
Top Boating Experts
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Boating Expert? Answer questions, earn points and help others
