Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
LG dishwasher is dripping water from vent onto floor
The vent for steam is on the front bottom of the dishwasher and sometimes it drips a lot of water on to the floor.
  • corydooley Mar 29, 2009
    Thanks for your inquiry but we fixed the problem by cleaning the gasket (hard water build up). I also saw on another website that our type of LG dishwasher doesn't work as well WITHOUT jetdry. So I refilled the reservoir and it's working great and not leaking anymore.
  • Jeff Meyer May 11, 2010
    -I understand that the model number of this dishwasher is LDF6810ST. Correct?
    -Also, please provide the serial number because with the symptom you are describing, it is important to know which manufacturer version you own.
    New Friend:
I have steam coming out during dry cycle wetting my floor. What is the kit that LG has developed and where can I get it?
Posted on Apr 27, 2010
  • 423 Answers
Good that it is working. Recommend you keep a lose eye on the vent on the bottom of the door panel. This model will probably begin leaking again if it has not been retrofit with a kit that LG developed.
Please open a new problem when it starts to leak and please provide the Model and serial number when you do. Good Luck!
Posted on Mar 30, 2009
6ya staff
SOURCE:
Unit is leaking water from somewhere
Upper drip pan drains clogged, water overflowing onto the floor.
Remove the rear cover of the unit and clean it thoroughly wit a vacuum. Let the unit fully defrost. Use a can of Air duster (for pc's) with the little hose on to clear the drain holes in the upper drip tray. Clean dirty evaporator fins with windex and toothbrush, flush with water. Excess condensate should now drain into the bottom tank instead of overflowing ontot he ground. Be sure to drain the bottom tank thoroughly. With the unit cleaned it should now vent condensate out the warm air duct rather than letting it build up in the unit.
Jul 06, 2012 | Windchaser PAC9 Air Conditioner
Water leaking from freezer forms ice on bottom of the freezer needs to be removed every week or leaks onto the kitchen floor. water coming from back wall of freezer from what appears to be vent cracks in...
Hello and Welcome to FixYa!
Well, it seems like the drain pipe or the drain channel is clogged, and the defrost water from the evaporator coils is dripping through the quoted regions, down to the base. Try checking the drain hose/ channel and remove the clogging if any (Blow some moderate temperature air through the channel and check/ remove any permanent clogging If any). Feel free to ask the details, or any question relevant to the trouble..
Concerned.
Aug 11, 2011 | LG LRDC22731 Bottom Freezer Refrigerator
The 2 metal "clips" that secure the dishwasher to
door gasket possibly bad or another leak. Stop using dishwasher until repaired or you're likely to ruin your floor. I just had this problem before we found a leak and now we may have to replace the kitchen flooring.
Order new clips or the dishwasher could fall out onto the floor or even onto your foot.
Nov 16, 2017 | LG LDF6920ST Stainless Steel 24 in....
Water dripping from front left side of dishwasher
feel the botom of the door is it leaking from a plastic tube on the left between the door shell,if ti is you need a vent ***. good luck!
ERIC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 26, 2010 | LG Dishwashers
Bosch SHU4302 DW has a leak in the bottom left. I cleaned the gasket etc. but no luck. Slow leak drip by drip in the wash cycle. This model does not seem to have the steam vent that other Bosch models...
I've got a 4306, and while it never leaked, the bottom door gasket did seem to chemically melt over the years.
I replaced it a few months ago. I don't know that a steam vent is needed as the gasketing system never allows any steam pressure to build. And, if anything, in general, the gaskets are in worse shape now than when the dishwasher was new, so leakage due to steam pressure would have been greater when new.
Dec 18, 2009 | Bosch Dishwashers
Roper Dishwasher leaks from float or float switch onto floor
you could be usiong way to mauch soap try filling only one of the soap trays or even try doing one wash without any soap at all
this unit tends to do this if you have to much soap in the unit left over from the last load...
beyond that your machine is proibaly tilted to far forward you can lift it, by lowering the front legs begind the toekick
Oct 25, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Steam coming out near bottom of door causing water to pool
Steam coming out is not normal and you should get it serviced soon. While not dangerous, it probably means that water is leaking inside the door panel from the "Hybrid Drying System" that is a feature which LG uses/touts. Other disheashers use a conventional condensing drying system.
The moist air enters through the internal drying system in the door panel, dry air is added from the outside air with the help of a fan and that air is routed though ducting down to the bottom of the door.
That system is clearly broken. If you have more questions on this, please reply. Good luck!
Mar 19, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwasher maytag 945 awq
Door gasket or sealOver time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Nov 08, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Water dripping outside the collector
I think that there is a 90 degree bend in the outlet on the bottom right front side of the collection tray that gets pluged with dirt, line etc. You can see this when you remove the collection container from the unit. I used a small piece of wire to clean out the hole and now the water goes into the tank and not onto the floor.
Aug 24, 2008 | LG LHD45EL Dehumidifier
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
1,943 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Lollo Pop
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
