Did you replace the lamp with a Sony original. Make sure the lamp is fully engaged into the socket and the lamp door is properly closed. Do you have any error lights blinking on the front panel now??
You can't post conmments that contain an email address.
Re: the power light keeps on blinking red three times...
OK. Great! 3 times is simple. The lamp door is not properly closed or the lamp is not fully engaged into the socket. Most likely it is a door issue, though.
Hi, Is is standby light blinking red or any other light? Let me know how many times red standby light blinking after three seconds long pause to provide you helpful info. It seems pop sound was due to broken lamp, please check lamp inside tv and if it is broken, replace it to solve tv problem. Hope this will help. Thanks.
Hi, If red light was not blinking before lamp replacement and after that it start blinking 3 times then pause for three seconds and again blink, check lamp cover that has not been fixed on tv or it is not fixed/ seated correctly there. Lamp cover is first thing that you removed from tv to replace lamp. Hope these info will help. If red light is blinking other than 3 times, let me know how many times it is blinking along with tv model number written at rear to provide you helpful info. Thanks.
Hi, If red light blinks 3 times when tv refuse to power up then check lamp cover that was removed to replace lamp, make sure lamp cover is fixed in its position securely and screw is tight. Let me know how many times red light is blinking after three second long pause IF it is not blinking 3 times. Thanks.
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Your lamp door switch or lamp switch (there are 2) may not be fully engaged or one may have failed. Try seating the lamp again, you may not have it fully installed.
Please recheck Lamp Cover and make sure it is fixed in its space securely as 3 times red blink shows lamp cover error. There is small safety switch in TV cabinet under lamp cover that has to be pushed by lamp cover if it is fixed in its position properly. That switch is not being pressed by lamp cover and causing this error. Thanks.
Hi, Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number... A1085447A* LAMP BLOCK ASSY XL-2200U It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
Does the light blink? If it is blinking a 3 code, the IC's need to be replaced. Those three lamps as you called them are not lamps, they are the three picture tubes.
