I just picked up a used Aastra 9116 and liked the idea of the caller list and programmable phone directory. Now that I'm programming it I'm finding that the buttons don't work consistently. For example, I can press the Options button and nothing happens, it works like it is supposed to, or sometimes the "Set Language" message appears and then disappears again. I am glad that I can still send and receive phone calls - it is just the extra feature buttons that seem to be malfunctioning.
SOURCE: aastra telecom 9316 cw
Yes:
http://www.aastratelecom.com/cps/rde/xchg/SID-3D8CCB73-12A0DEC9/03/hs.xsl/21564.htm#dl_instructions
Look at the bottom of page.
SOURCE: different language
Here is english manual www.aastratelecom.com/cps/rde/xbcr/SID-3D8CCB6A-18527B12/03/9116_ma_en_0304.pdf page 10. talks about changing languages.
SOURCE: How do I call forward this phone to my cell?
Forwarding is through the plan provider and part of the voice mail system.
SOURCE: Cal do you use the
In order to set call forwarding on this telephone, must first have the feature CFV (Call Forward Variable) on in the line. This feature can be provided by the telephone service provider.
A typical feature code for this is *72 to activate CFV and *73 to deactivate.
You can program these features on the M9316 telephone by do the following:
CFV activate
1) Press the SAVE key.
2) Then select the key where you want to program the feature.
3) Then enter *72 (optional: plus the telephone number of where you want the call to forward to).
4) Press SAVE twice.
CFV deactivate
2) Then select another key where you want to program the feature.
3) Then enter *73
Be sure and label your buttons.
To use go off hook and press the key you just programmed.
