Hello Christine, so you mention your Techwood
would have possible problem in the amplification stage
I suggest you disconnect all the speakers and check if it continues to protect, if not, see reconnecting the speakers one by one and testing, control the speaker cables are in good condition
If you repeat the Proteccion fault, I suggest you look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Christine, por lo que comentas tu Techwood
tendr?a posible problema en la etapa de amplificaci?n
Te sugiero que desconectes todos los parlantes y comprueba si se sigue protegiendo, sino lo hace, ve volviendo a conectar los parlantes de a uno y pruebas, controla los cables de parlante se encuentren en buenas condiciones
Si repite la falla de Protecci?n, te sugiero que busques un servicio t?cnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
https://data2.manualslib.com/pdf3/66/6543/654206-techwood/plr85.pdf?a40157a995f084aa8ff4e7be48a929e0&take=binary
hey those 6 codes did not work i am useing a comcast universal remote so idk could it be cus its a comcast remote???
