Sharp 27R-S50 27" TV Logo
Posted on Aug 22, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No power tv comes on for about a minute then shuts down and wont come back on. it appears the horiz- out is not running and there is no voltage coming from the regulators on the secondary side of the low voltage supply.
Anonymous
Level 3:
Genius:
  • Master 1,153 Answers
  • Posted on Aug 22, 2007
Anonymous
Master
Level 3:
Genius:
Answers
1153
Questions
0
Helped
324865
Points
2386
Look for high voltage cap like 200-250v 100uf that could be bad around flyback. Also look to see if reg. shorted, and horz. output bad.
Why does my TV shut off when the OPC light comes on?
Have you got some voltage readings when the set shuts down? Do the voltages remain normal like they're when the set is working?
Flat panel TV comes on by it's self
It sounds that the voltage output from its internal power regulator board is not proper. Check it.
2answers
Tv wont turn on and has a high pitched sound while plugged in
your flyback transformer and driver circuit are operating, but the horiz. output transistor that needs to be in circuit w/horiz output transformer is open and can't amplify the signal needed for the flyback xfmr
Come on then line horizal across screen then turs off
Horizontal line (up and down) is know as horizontal collapse. This is usually located around highvoltage section of the circuit. Because this circuit depends on certian frequencies and voltage protection circuitry will shut the set down. This will need a trained tv technician to fix this and can be expensive depending on the parts needed.
Rca flat scren hd tv
Examine horiz circuit with magnifier.....look for bad solder
connection.............check power supply area and solder pins of
horiz output transformer.............T.
TV shut down while watching
Install horiz driver kit # 483513057673....applies to all L04.1
chassis.....+ replace 47mf/25v cap in horiz driver circuit...T.
Sony projection tv model kp-61v90
possible power supply or short on the b+ run,check for shorted horiz. o/p tranistor.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
