We are FIXYA dot com, we are not Phonic and neither is Catherine. We are just folks like you trying to help folks like you because we can. Yes, there is a Phonic category, but that is just good housekeeping here on the site.
Could not find a free one online but did find a PDF download for 10 Euros at the folllowing website: http://home.versatel.nl/manualswarehouse/manuals.htm use the menu on the far left hand side to scroll to Phonic and then to peq 3300, then select pdf to download it.
You will plug an UNBALANCED 1/4 inplug cable into the MONI jack on the front of the unit. The other end will probably need to be an XLR plug to connect to the Kustom POWERED monitor. Please note that the UNBALANCED output of the Phonic is NOT good engineering practice. The Phonic stuff is normally low-end and they don't do everything correctely, although for a small system it should work. IF you get excessive hum from using a long cable to the Kustom with a "Kludged" unbalanced to balanced cable, you MAY need to use a DI box at the Phonic end to convert the unbalanced Phonic MONI output to a balanced line (XLR to XLR) for a longer run to the Kustom monitor. You might get a 1/4 inch TS to XLR balanced plug that has a transformer in it and use an XLR to XLR cable to the Kustom. Please note that having this plug in the Phonic hangs out and is easily bent over so I would recommend using a right angle connector at the Phonic and plug the 1/4 inch TS to XLR adaoter into that so the yanking of the XLR cable won't break the 1/4 inch adapter off in the Phonic.
