When ever I wash blankets the washer gets out of balance. It takes about an additional hour to move blankets around are restart 3 or 4 times before it can finish
does it drain water, seems like it's gonna spin then starts filling up again? if this is what's happening it mean the washer is sensing that the load isn't balanced and it fill back up to move the clothes around and tries again, it will keep doing this untill it senses a balance of weight in the drum. if she tries moving the clothes around herself before it done draining she maybe able to keep it from doing this
only wash 1 to 2 blankets max and set water to high when you put them in start with a corner and go around the center plunger and feed them in as equal as you can it should help if not at least not as bad the machine may need to be leveled as well this is very very important for a washer mope this helps
I don't know if this is a new washing machine or not, but I would recommend is getting a few small thin boards and making sure the machine is level. If this doesn't work there could be a bad sensor, but that doesn't seem like the case to me as moving the machine a little gets it to restart.
The water temp thermostat is to blame or the water is not heating.Basically what happens is the washer fills with cold water and starts to wash and heat at the same time.Once the water reaches a certain temperature it moves onto the next stage of the wash program.If the water is not heating or the thermostat is not working the programmer wont get the signal to move on.Hope this helps.
it could be weak shocks for the drum or the springs. you can also overload the washer. there should be a gap in filling washer with clothes around 5-to 6 cm's on the drum ring this gives space for movement and balancing. the washer can also become out of balance if the bearing is damaged, if you can lift the drum from the bottom of the ring and it moves up and down by few millimeters and feels lose then its usually a sign the bearing is weak. this can make the display say there is a problem with balance. 6kg or 7kg is the weight of the clothes and water not the clothes. over loading the washer damages the bearings and put more pressure on the shocks and springs.
There are 2 things you can do.
All washing machines have an off balance shut off, some are touchy, some let it run around the house. With wht machine empty, lean it towards you, on the 2 front feet, about 2 or 3 inches and let it drop. The self leveling feet in the rear must BOTH make good floor gontact and sometimes, just the weight of the machine will not adjust them. The other thing is, make sure the load is evenly distributed. Coats, blankets, small rugs etc. are very heavy when wet and they tend to throw all of the weight to one side.
There is no screw holding the yub in place. It hangs on the center post, where the agitator goes. There is however, what's called a snubber. It is a rubber device that looks like a flattened suction cup, that comes in contact with the tub. It helps keep the tub from jumping around too much.
I have the Fisher and Paykel model GWL15 and could not be more disapointed with it. It has been leveled more times than I can count, and 9 out of 10 times it goes out of balance and beeps. It takes me 3 hours to do a small load, and that is with me placing every sock and shirt carefully opposite one another. This thing is just pure junk, and it makes me sick to think what I paid for it. I will just place it on the curb and buy a cheap washing machine to replace it. My blood boils every time I come to the basement to check the wash and hear that stupid beep! I love the dryer, but do yourself a huge favor and don't ever buy a Fisher and Paykel product.
remove console screws behind timer is lid switch if you have a volt/ohm meter with washer disconnected ckd switch operation also there is a fuse on same assembly ck it
It can be from one blanket to three.
how many blankets are you putting in there?
