My KEN-MORE refrigerator is leaking water . I have replaced Pcp Board & Heater & SENSOR. What can I do Next.
What is your model number? Sears Kenmore numbers look like this 321.2468102 I hear a lot of complaints from people that see water leaking into their refrigerator from seemingly nowhere. Water appears in different places and even inside or under a refrigerators that does not have a water or a ice dispenser! Frost free refrigerators defrost the ice that collects on the evaporator coil. Your refrigerator defrost on the average about every 8 hours so the water that accumulates during defrost has to go somewhere right? Yes the water is supposed to drain down a small drain line to a pan down near the compressor where warm air from the condenser fan will blow warm air over the water and evaporate the water again an put it back into the air inside your home, office or wherever your refrigerator is located. Over time that little drain tube gets slime, algae and a gooey white paste gunk that fills the drain line sides up stopping the waterflow downward to the condensate pan below refrigerator. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers. Gunk is an accumulation of algae slime and just crud that appears from nowhere in a refrigerators defrost condensate drain line. How a refrigerator leaks is not always the same with every model as you may see frozen ice flowing down the rear wall of freezers on side by sides. Here is an example of a ET18PKXGTO Whirlpool refrigerator leaking water into a cup below the freezer compartment. Click here=> Whirlpool Leak Photo taken by TechnicianBrian. TechnicianBrian.com. And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
SOURCE: water leaking inside the refrigerator
Hi
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
SOURCE: water line broken for Kenmore refrigerator near compressor
Cut off a piece of line and go to a good hardware store, they can show you how to fix it. Need a coupling, and a nut and ferrel. House water line goes on one end of coupling, nut and ferrel on the broken water line on fridge. A good hardware store will be able to show you how to fix.
SOURCE: refrigerator is leaking water into drawers and out on floor
Your defrost drain is clogged . Remove the rear freezer panel and using a hair dryer , defrost the aluminum tray below the coils . When you see the drain hole , defrost it and use a small tube to insert and blow thru to remove any possible "gunk" . You may have to use a little hot water to help defrost the drain , but keep at it until you can blow thru it .
SOURCE: My kenmore side by side refrigerator model
Icemaker leaks are common and cannot always be solved. May need a new Icemaker. Ofter you can obtain a kit from Lowes (use a Whirlpool kit.)
SOURCE: I have Kenmore refrigerator,leaks water inside.
Is there an ice maker in the freezer? If so, check all fittings, otherwise, this is condensation, which is VERY common & is actually expected, especially in summer months. There should be a small hole in the bottom, center, under the crisper drawers, make sure that it is not blocked up. The condesation (water) that builds up goes through that hole into a condensation drain pan & gets cooked off by a little boxy thing (golly I forget the correct term & my husband is a refrigeration tech) that warms up or simply evaporates in to the air. The water you see is NORMAL, but your drain may be plugged up, so go have a peek to make sure it's clear, if not, just clear it out & you'll be good to go. Good luck.
