Engine won't turn over to start
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
SOURCE: 5 HP Briggs and Stratton Engine
Take the coil off clean with sand paper then get a piece of cardboard from a cereal box or cigarette box, put the piece of cardboard in between the coil and the magnetic strip on the flywheel ''believe it or not it is the perfect gap'' 'let the magnet pull the two together'' then tighten the coil down. if still no spark get a new coil.
SOURCE: Fuel in tank going into engine and mixing with oil
The float needle and seat are leaking and not shutting off the fuel when carb bowl if full. It then flows down the intake into the cylinder, past the rings and into the crankcase. Have the needle and pressed-in brass seat replaced. Could save yourself some money if you removed the carb yourself and took it in.
SOURCE: lawn mower stalls when engine is hot
first thing is to check that plug is not fowling up when hot due to motor burning to much oil.
