This of course depends on why the light is on! If you had a fax come in and it is in memory, you will need to print the fax and clear the memory before the light will go out. The LCD Display should be telling you why that light is on.
1. There is a fax or print job in memory waiting to be printed.--> See steps below
2. There is a paper jam --> Open printer - Remove all paper - Close printer - press OK button
3. You are out of ink or the cartridges are low. - Change Cartridges
Solution: Printing reports and lists MX310
The table below shows the reports and lists that can be printed from your machine.
Report or List
Description
ACTIVITY REPORT
Shows recent facsimile transactions performed by your machine. You can enable or disable automatic printing of this report after every 20 transactions. You can also manually set the machine to print it.
CODED SPEED DIAL
LIST
Lists the destination numbers and names registered for coded dial speed dialing.
USER'S DATA LIST
Lists the current settings of your machine and the registered sender information.
MEMORY LIST
Lists the documents currently stored in the machine's memory.
TX (Transmission)
REPORT
Prints after transmission of a document.
You can enable or disable this feature, or set the machine to print a report only when an error occurs.
You can also set the machine to print the first page of the document under the transmission report to remind you of the contents of the document.
RX (Reception)
REPORT
Prints after reception of a document.
To print the Activity Report, Coded Speed Dial List, User's Data List or Memory List:
1 . Press <FAX>, then press <Menu>.
2 . Use to select [PRNT REPORT/LIST], then press <OK>.
3. Usehow do you turn off the in use/memory light? - leftright.gifploads/images/leftright.gif" alt="leftright.gif" class="h_mi" /> to select the desired report, then press <OK>. The report or list is printed.
Ready light does not turn on and the camera does not work.
Turn on the camera (Turning on the camera).
Install new batteries (Loading the battery) or charge rechargeable batteries.
Turn camera off, then back on.
Ready light blinks green.
Camera is operating normally.
Ready light blinks amber.
Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Transfer pictures to the computer (Transferring pictures with the USB cable), delete pictures from the camera (Deleting pictures/videos), switch image storage locations (), or insert a card with available memory (Using an optional SD/SDHC or MMC card).
Wait. Resume picture taking when the light turns green.
Change the image storage location to internal memory (), or use a different card.
Ready light is off or glows steady green.
