Note: This device uses a Reduced Size Dual Voltage
(1.8/3V) MultiMediaCard (RS-MMC). To ensure
interoperability, use only dual voltage RS-MMCs. Check
the compatibility of an RS-MMC with its manufacturer or
provider.
Use only compatible Reduced Size MultiMediaCards
(RS-MMC) with this device. Other memory cards, such as
Secure Digital (SD) cards, do not fit in the memory card
slot and are not compatible with this device. Using an
incompatible memory card may damage the memory card
as well as the device, and data stored on the incompatible
card may be corrupted.
You cannot use the memory
card if the door of the
memory card slot is open.
Format a memory card
When a memory card is reformatted, all data on the card
is permanently lost.
Some memory cards are supplied preformatted and others
require formatting. Consult your retailer to find out if you
must format the memory card before you can use it.
To format a memory card, select
Options >
Format mem.
card. Select
Yes to confirm. When formatting is complete,
enter a name for the memory card, and select
OK.
thnku...yes it is readn the card and showing the used memory and free memory.But after that the mobile remains hanged.i am not even able to switch it off.have to take the battery and then restart it.i kept pressing the pencil button after switching on the mobile.
