Nikon Coolpix 2200 Digital Camera Logo
Posted on Aug 21, 2007
Nikon coolpix 2200 zoom
While swithcing on the camera the zoom gets extended on its own till full capacity and the zoom buttons does not work.Pressing on the zoom reverse buton afterwards also has no effect and the lens remains in full zoom including digital zoom.
  • scott18 Dec 21, 2007
    Ive had the same problem with my coolpix 2200. I was taking photos and zoomed in for a close up shot and now when I try to zoom out again the camera doesnt respond, I have to completely shut the camera off so that it automatically pulls the lens in and then switch it back on, but as soon as I use the zoom function it just sticks again. Ive never dropped or banged it so I dont understand how or why its jamming like it does.
A
Anonymous
Based on your description, it certainly sounds like the zoom button is stuck or shorted. If you're comfortable with taking it apart, I'd try getting to the zoom electronics and see if there's any noticeable damage. Whenever I try something like this, I like to see how much damage I could cause first. eBay has sold this item for less than $50 with shipping (just in case you break something). You can also look there for parts cameras -- one listed for $10 with free shipping that might give you what you need.
Nikon coolpix s9900 zoom extends full out on startup making loud noises
Hello Karen, I am getting the same issue. Did you get it fixed?
Have an issue with my cameras zoom function. When I take pictures my zoom works perfectly but when I switch to record mode the zoom will no longer work.
Nikon Coolpix S220 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_S220_Troubleshooting
iFixitThe Nikon Coolpix S220 is a compact 10.0 Megapixel Digital Camera. Designed with a 2.5 inch LCD ... If camera is in Video Mode the optical zoom will not work.
Nikon Coolpix L810 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_L810_Troubleshooting
iFixitThe zoom function is not working while camera is on; Zoom is not available in ... If your camera does not turn on, make sure that the battery is fully charged. If after a charge the camera still doesn't turn on, your batteries may no longer be able ... modebutton, the playback button, or the movie record button doesn't work, turn ...
Nikon L830 review ' Cameralabs
www.cameralabs.com/reviews/Nikon_COOLPIX_L830/
2answers
Exit fhumbnail nikon coolpix
Rotate the zoom control to "T". If you go too far, rotate it the other way. See pages 73 and 74 of the manual: https://support.nikonusa.com/app/answers/detail/a_id/18250
1helpful
I dont get the format option on the coolpix 2200 camera
The Nikon 2200 works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Apr 10, 2013 • Cameras
2helpful
I cannot get the format option on the coolpix 2200 camera
The 2200 works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Stuck Zoom Function On Nikon COOLPIX L20 Digital Camera
U obviously broke more that just the lcd screen. Your lens assembly is now fubar so you will have to pay the piper to fix it. Or just get a new camera.
Nikon coolpix 2200 zoom problem
I was having a "Lens Error" with my Nikon Coolpix S210 camera and this websites' tips fixed my camera.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
1helpful
Exact same troubles.
i think you've got a stuck zoom in [+] button. was this camera left inside a cabinet ...or some damp place for some time?
Coolpix macro problem
I called customer suppot.
Follwed these steps:
1. Make sure camera and subject are perfectly still
2. Push flower button till white flower is on screen
3. slowly press zoom in and out till flower turns yellow
4. wait 10 secondes or so
5. camera will focus on object
6. if not, press zoom in/out again, then wait again
Nikon coolpix 2200 zoom mechanism
If the lens assy is not responding to zoom buttons then the camera is in confusion mode due to a sensor being blocked or defective. Normally it would go thru a startup cycle to initialise position of various parts in the lens assy and give back control to you but in your case it is not getting that signal and in your case I would bet on the end sensor.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
