Computers & Internet Logo
A
Anonymous Posted on Jun 18, 2013
83 coordinates graph spongebob ti - Texas Instruments TI-83+ Graphing Calculator (TEX83PL)
5 Related Answers
Patrick
  • 56 Answers
  • Posted on Nov 12, 2008
SOURCE: Graph feature is not working on TI-83
you have one of your stat plots on that is what is messing it up. So either turn off the stat plots. Or just reset your calculator. hit 2nd then the plus (+) key then 7 then 1 then 2. Good luck
Anonymous
  • 4 Answers
  • Posted on Feb 03, 2009
SOURCE: TI-83 Plus Graphing Error
Try zoom 6
Anonymous
  • 69 Answers
  • Posted on May 11, 2009
SOURCE: How do I graph parabolas?
Parabolas are forms of the base equation X^2. So press the [Y=] key, and then type in the variation of x squared that you want
Anonymous
  • 69 Answers
  • Posted on May 14, 2009
SOURCE: when i try to graph a scatter plot on my ti-83
Your stat plots are on, and may not be filled out/ correctly filled out.
go to [Y=] and go up to the stat plots ([Plot 1], [Plot 2], [Plot 3] ) and turn off the ones that are "ON" ( highlighed black w/ white text.) and press [ENTER] on the ones that are on and the problem is no more.
k24674
  • 8093 Answers
  • Posted on Sep 27, 2009
SOURCE: having trouble with my TI-83 plus
Some old junk is in memory. Reset the memory to defaults and everything will be fine. It is a good practice to clear memory before a new calculation.
To reset memory
Press [2nd][MEM][7:Reset][1:All ram][2:Reset] [EMTER] . Clear screen and enter the functions you want to graph.
Hope it helps.
Ti 83 only graphs circles
Press "Mode" to go into your settings. Make sure that you are not set to graph "Polar" coordinates. If you are, change the setting back to "Func" or "Function".
6answers
Equations
You can't simply enter 7x+9=30 into the calculator, there is a way to calculate what the x is but its been a few years since I've done these..
How to graph the negative cosine on the graphing calculator texaz instruments TI 83 plus
do you mean (-)Cosine(X), or arcCosine(X)
The first is graphed as "-cos(X" (no quotes)
The second as "cos-1(x" (press 2nd Cos to access arcCosine)
7helpful
TI-83 Plus Calculator: My TI-83 reads "INVALID DIM" when I try to graph a...
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
1helpful
Whenever i try to link my calculator with other ones it always says error in xmit. no matter what i do
Read the following answer from the TI Knowledge Base.
Hope it helps.
How can I troubleshoot an Error in Xmit error message when transferring data between two graphing calculators?
The Error in Xmit error message is returned when a connection cannot be established between two calculators when attempting to transfer data. There are several factors that can contribute to this error message.
• The calculators being connected are not compatible for data transfer.
• The data cable is not firmly connected to both units.
• The receiving calculator is not in receive mode.
• The I/O port on one of the graphing calculators is damaged.
The procedure for connecting two graphing calculators is as follows:
• Connect the data cable to the I/O port of each unit. The cable will fit tightly in the I/O port and snap into place. If silver from the cable is visible, the cable is not properly connected.
• Access the Link menu on each unit
• Place the receiving graphing calculator on "Receive"
• Place the sending unit on "Transmit" or "Send" from the Link menu.
Once the data has been selected, the transfer will commence accordingly.
The data transfer protocols for graphing calculator is as follows:
• TI-73 - Link allows data sharing with another TI-73, TI-82, TI-83, and TI-83 Plus.
• TI-82 - Link allows data sharing with another TI-82.
• TI-83 - Link allows data sharing with the TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-83 Plus/TI-84 Plus family- Link allows data sharing with another TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-85 - Link allows data sharing with another TI-85(To a TI-86. Not From a TI-86).
• TI-86 - Link allows data sharing with another TI-86 and from a TI-85 to a TI-86.
• TI-89 family- Link allows data sharing with another TI-89 family calculator and from a TI-92 family calculator.
• TI-92 family- Link allows data sharing with another TI-92 family calculator and from a TI-89 family calculator.
• Voyage™ 200 - Link allows data sharing with another Voyage 200 and TI-92 family calculator.
If the cable does not fit properly into the I/O port, or if the I/O port appears to be damaged (broken or separated plastic, obstruction inside the port), call 1-800-TI-CARES (1-800-842-2737) M-TH 8:00 AM - 7:00 PM FRI 10:00 AM - 7:00 PM Central Standard Time to speak to a representative or sending an email to [email protected].
Graphing on ti-83
Press the y= button on the far left under the screen then type (1/5) then press the X,T,n button then minus 2. Press the GRAPH button on far right under the screen.
5helpful
Can not use graph function
How do I fix my Ti 83 calculator's window range error and do the graph?Because without that fixed I can't do my graph atall.
1helpful
Graphing calculator help
The cord that comes with the TI-83 Plus is a unit-to-unit link cable. It allows you to share data from one TI-83 (or other compatible TI calculator) to another. If you have the optional TI-GRAPH LINK adapter cable and the appropriate software it can also be connected to a PC.
For more info, here is the link to the manual. Chapter 19 discusses it in great detail.
http://education.ti.com/downloads/guidebooks/graphing/83p/83m$book-eng.pdf
Hope this helps..and good luck!
Top Texas Instruments Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Texas Instruments Computer and Internet Expert? Answer questions, earn points and help others
