I would love to know how long this problem has been posted ... I have the same problem ... how bizzare ... when I read that two others have this problem I knew there must be a solution (but know one solved it yet). I haven't used my bedroom tv for I don't remember how many months (good news - it got me and the kids spending more time together - tv or otherwise, rather than being in separate rooms) anyhow ... finally fed up, received free upgrade satillite receivers and I was bound and determined to find the solution (or conceed and buy a new tv - who has the money these days, right) well sifted through the on-line manual ... whoa la ... it's the Front Panel Block (turned on) didn't even know it had this feature ... to turn it off press and hold the power button (I used the remote) for 6 seconds (count slowly ... like one mississippi, two miss issippi, and so on....) HURRAY!!!!!!! I hope I made someone elses day.
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
2. Press and hold the CODE SEARCH/SETUP button on the remote until the
INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming (TV, VCR,
DVD, etc.). For AUX, press AUX then the device button you are assigning to
AUX. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the
GE Universal Remote. After your code is entered the INDICATOR LIGHT will
turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the POWER
button. Your device should turn off
OK
Hi
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD
Player Combo press DVD/VCR once. After programming a VCR Combo device,
you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a
DVD Combo device, you will be able to control channel selection, volume, and
DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes to locate the type of device and brand name and
then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device
should turn off. If it does not, repeat steps 2 to 5, trying each code for your
brand until you find one that works. If it still doesn't work, try Searching
For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when
the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are
searching for.
Thank You
