This is from the seventies and I am not sure how to use it as I was given the machine without the book.
SOURCE: Braun MP50 juicer problems
I suspect you have solved the problem by now, if not, this worked for me. First unscrew the white center screw. Then as you lift up on the metal basket you should see the black center screw lift slightly. while holding upward pressure on the basket, tap the black center screw down. the basket and cutting disk should pop free. hope this helps.
