When trying to connect my PC (Compaq Presario CQ45) to my TV via the HDMI ports does not work. Any suggestions?
Thanks, Ian
I will assume it a display resolution issue. Try to set your laptop display at resolution 1280x720 or 1920x1080, as this will be the max res. for that tv.
give it a try and let me know about the outcome.
You will have to enable the HDMI output on your Compaq notebook as the port is usually turned off to conserve resources and power if you are using the battery. Simply, it needs to be turned on within the notebook.
Trying to connect samsung t217s to hdmi on tv
