Heard a loud noise in the upper freezer side, but now freezer doesn't work. had ice make on it also, obviously not working also. I have unplugged it, will let it set for an hour or so, I took off the bottom cardboard to get into back of freezer. how do I get the casing off? I can see only the compressor and coils. I need to get in the upper portion of the back of the unit. please help.
Good Morning Patty - Often when the unit is not cooling properly, it is because there could be a coolant leak or an issue with the internal sealed system including a faulty compressor or evaporate fan. Are you referring to how to access inside the cabinet of the unit? If so, unfortunately that would not be possible. All freezer components must be accessed from the inside the freezer compartment. I have located the Parts Manual on the manufacturer website for the model number posted above. Hope this information proves to be helpful and please feel free to reconnect if you have any further questions.
SOURCE: Frigadaire freezer cold but fridge compartment is warm
i need the complete model number to narrow it down they still make the frs20zrg to this day the last two numbers like frs20zrgwo or frs20zrgw9 is what will tell me what kind of defrost system it has the serial plate is in the fridge side up by the light bulb or on the left hand side or right hand side of the fridge compartment up near the top sorry to be a bother but its necessary
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
SOURCE: Water accumulation in bottom of freezer in Frigidaire FRS26ZSHB5
take out everything and at the lower inside back of the freezer you have a drain ..... pour hot water till it opens / the water comes from you evap when it goes into defrost and it cant get out the drain / Larry
SOURCE: fridge not getting cold. freezer not freezing
Well I called a repaireman and it was a part in the freezer that controls the defrost. He fixed it and all is well.
SOURCE: Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Testimonial: "I turned off the freezer side and it defrost for a few hours. Then I turned it back on and its working fine for 2 days now. "
