Computers & Internet Logo
Anonymous Posted on Jun 17, 2013
Msi ms1719, where can i get a recovery disk for this laptop
Anonymous
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 67 Answers
  • Posted on Jun 17, 2013
Anonymous
Expert
Level 2:
New Friend:
Greenhorn:
Answers
67
Questions
0
Helped
8619
Points
142
A pc mechanic will have universal or multi purpose recovery disks.... you should try getting a windows boot disk and just doing a system refresh, u can buy from best buy or a pc mech
My msi A6200 laptop goes thru the installed things again again. Won't let me go to recovery or reset... help. What keys do I press
Hit the F8 key during the bootup and if menu pops up select "last known good bootup" and hit enter - see what happens.
Or use the recovery disks that came with your unit or that you were supposed to make. If no disks you may be able to purchase from MSI. Otherwise you will have to do a clean install of the OS from regular install disks.
How can I recover my cr700 when after going into recovery mode I have nothing on screen.the mouse works but blank screen.i get the win logo and loading windows files but nothing after that. I have tried...
If you have backed up your data (photos, documents, etc.) on an external hard drive, USB disk, DVD's.
If there is company data, or otherwise valuable data, this is better left to a professional! If you are able to cope with the possible loss of all your data, feel free to continue reading.
If you're unable to backup your data, you might try to do so with:
Easeus Data recovery Wizard
Data Recovery Wizard Free 8 6
After you have baked up your data. You could try to recover windows from the error by:
-Pressing F3 repeatedly when the unit is powered on.
-This will get you a menu to load Windows, or Windows recovery
-After this, select "Windows Sytem Recovery Options"
-Follow the on-screen options to try and fix the issue
-If this doesn't work, power on the laptop again and press F3
-load up the Windows option that you are given
!THIS WILL DELETE ALL YOUR PERSONAL DATA AND RESTORE THE COMPUTER TO FACTORY DEFAULTS!
-Select "MSI Recovery Manager"
-IF YOU ARE SURE IT'S OKAY TO LOSE ALL DATA: "OK" > "OK"
-IF F3 Doesn't work, either your recovery files are missing, or your hard disk is failing. If this is the case, you can read on at:
Reinstalling Windows when recovery fails MSI HQ User to User FAQ
Hope this helps!
1helpful
How do I return my msi wind u180 to factory settings
Use the recovery partition on your MSI laptop to recover its original factory settings. Recovering your MSI laptop to its original factory settings will resolve problems with instability that you may be experiencing as a result of missing system files that were accidentally deleted. Recovering your MSI laptop to its original factory settings will also completely remove any viruses on your computer's hard drive that you were unable to remove with anti-virus software. Fortunately, you can wipe all of the information off your laptop's hard drive and start with a clean slate.
Instructions
  • 1
Turn on or restart your laptop. Press "F3" repeatedly when the MSI logo appears on the screen during the boot process to be redirected to the "Windows Boot Manager."
  • 2
Highlight "Windows Setup [EMS Enabled]" using the arrow keys on the keyboard. Press "Enter" to access the recovery partition on the hard drive of the MSI laptop. The "System Recovery Option" dialog box will appear on the screen. Click "MSI Recovery Manager." Click "OK" when a message appears on the screen notifying you that your computer will be restored to its original factory settings.
  • 3
Click "OK" when a message appears notifying you that the hard drive will be formatted to begin the recovery process. A dialog box with a status bar will appear to indicate how much time is left in the recovery process. Depending on the size of your hard drive as well as how much personal data needs to be erased, the recovery process could take up to 45 minutes.
  • 4
Click "OK" when a dialog box appears on the screen indicating that the recovery process is complete. Your laptop will automatically restart and boot up to the Windows setup screen, where you can begin personalizing the settings for your Windows operating system.
How to Recover an MSI Laptop to Original Factory Settings eHow
No recovery disk for msi fx700
The recovery disc is partitioned on the hard drive. when it boots up look for the verbage to tell you what function key to hit to run recovery. If this works then great. for me I had to email MSI, they replied back with a word document and I filled it out ordering a dvd of my recovery disc. it cost about $30.00. I had to do this because my hard drive crashed. working great now.
1helpful
Return msi ge620 to factory settings
Turn on or restart your laptop. Press "F3" repeatedly when the MSI logo appears on the screen during the boot process to be redirected to the "Windows Boot Manager." Highlight "Windows Setup [EMS Enabled]" using the arrow keys on the keyboard. Press "Enter" to access the recovery partition on the hard drive of the MSI laptop. The "System Recovery Option" dialog box will appear on the screen. Click "MSI Recovery Manager." Click "OK" when a message appears on the screen notifying you that your computer will be restored to its original factory settings. Click "OK" when a message appears notifying you that the hard drive will be formatted to begin the recovery process. A dialog box with a status bar will appear to indicate how much time is left in the recovery process. Depending on the of your hard drive as well as how much personal data needs to be erased, the recovery process could take up to 45 minutes. Click "OK" when a dialog box appears on the screen indicating that the recovery process is complete. Your laptop will automatically restart and boot up to the Windows setup screen, where you can begin personalizing the settings for your Windows operating system. Hope this helps.
b>
I have a msi u123 notebook and it has an error i want to format it using my usb how do i d it.. and also the system recovery of my laptop is lost i accidentally format it. can i still have that system...
Hi
its worth still trying this
power up pressing the power key as well as the F3 key on some msi laptops this will take you into
the factory recovery options
hope this is usefull to you
many thanks
1helpful
My smartbook does not want to turn on because of a error saying '' Application explorer exe. error '' what should i do?
you can recover your windows by recovery disk (if you have a recovery disk, due to specification of your notebook, it's use windows xp which has built as your original os, it means your notebook has a recovery disk) but you will lost your data in drive C (drive contains your operation system)
turn on your notebook
press f3 immediately from your keyboard
select MSI recovery manager
press OK
wait until the process of system recovery finish
When i turn it on the the screen would display "ntsl loader missing" im using xp and it would not start
it is missing the NT loader files--need to reinstall them from a recovery disc or XP disk
Laptop will turn on, but can't load recovery or driver disks and if i don't use those i get a disk read error press control alt delete.
click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
1helpful
When I turn on my MSI M510C notebook - ''reboot and select proper
Your notebook does not see the proper boot files on your C drive. Many times the boot.ini has been corrupted.
You will need a Windows XP Install CD mounted in the CD Rom. When you boot the system you need to choose the CD as the boot device (if the notebbok does not do it by default) then typr R to enter the recovery console. Once you get the C: prompt you will need to create a new boot.ini file using the bootcfg command. See the following website for details in using the Recovery Console:
http://commandwindows.com/recovery.htm
Grand Canyon Tech
Grand Canyon Tech
