Only themes only themes
SOURCE: HOW TO INSTALL THEME IN HTC TOUCH
Sync your mobile phone with Microsoft ActiveSync and open the Explorer icon. Open the following directory "My Windows Mobile-Based Device/Window" and copy and paste the *.TSK file into the Window folder. When the file transfer is done restart your phone. Once the phone has restarted tap the “Start/Settings/Today” and select theme you installed.
SOURCE: Not able to download software in HTC P3400i
Check with the HTC support center helpline or visit the nearest support center should have the contact numbers in the user manual "for the driver for vista". Also please show your phone the service center as there has been lots of patches for the models OS for correcting lots of problems which were present...should correct most of your problems and for sync try using bluetooh or if cable problem is preseistent after all the correction..don't waste time just sync using bluetooh, if not inbulit in your system by an additional bluetooh module hardly costs anything, works great and fast..have a nice day.
SOURCE: GPRS/MMS settings on HTC P3400i for vodafone postpaid connection
After browsing a lot of sites and experimenting with the settings finally I was able to configure my HTC P3400i with Vodafone Live support without any help from the Vodafone customer care (who were very bad and rude when I called them for getting the setting). The settings is working fine for me in Bangalore. Hope this helps all who bought this phone and struggling for getting the GPRS setting for HTC P3400i.
Below is the step by step instruction:
Step 1
Start->Settings->Connections->Tasks->Add a new modem connection:
Enter a name for the connection:
<give any name>
Select a modem:
Cellular Line(GPRS)
click next
Acess point name:
portalnmms
User name: <blank>
Password: <blank>
Domain:* <blank>
Go to Advanced->TCP/IP
select radio button "Use server-assigned IP address"
Go to Advanced->Servers
select radio buttion "Use server-assigned address"
Step 2
Start->Settings->Connections->Tasks->add proxy setting
Select "This network connects to the Internet"
Select "This network uses a proxy server to connect to the Internet"
Click "Advanced" button
Tap on HTTP
Server: 10.10.1.100 Port:9401
Username: <blank>
Password: <blank>
Domain: <blank>
Tap on WAP
Username: <blank>
Password: <blank>
Domain: <blank>
Step3:
Start->Settings->Connections->Advanced
In "Select which networks are automatically used"-> click the Select Networks
Programs that automatically connect to the Internet should connect using:
Select the Connection name which you configured in Step 1
Programs that automatically connect to a private network should connect using:
Make sure you reboot after doing above change.
please vodafone postpaid mobile connect settings
cant get a theme which supports the HTC p3400i
"provide me themes of htc p3400i
same prob
howto install themes in htc p3400i
