No there will not be a easy fix for this. You can keep putting up with this the way you have been or buy a new receiver and try to sell this one on craigslist, eBay, etc.
Possible that the cd disc has jammed due to a change in the disc- warming can bend some cd's, also if the cd is struck inside as the loading mechanism is struck. In both cases the set must be pulled out if there is no hope with trying to retrieve the cd softly assisting while ejecting. If you do not hear any noise while the eject is pressed then the loading drive is faulty , you need to remove the cd , open to check, If this is mechanical then you can softly push the cd out, if not the electonic section needs a check.
Sounds like the laser servo is kaput. I would try to find another E-11 on eBay for parts and swap out the laser R/W, as that Sony is a nice unit when it works.
There is always a small pin hole in the tray of the DVD. Insert a pin through it and the tray will open mechanically. After removing the disk press the tray to close it.
Loading gear jam or broken loading motor belt. Disasemble unit to remove disc and check operation of motor and gear assembly. Repost the results so we can better help.
in order to repair CD changer you have to be equiped with special tools and knowledge. This repair is only possibble in Authorized Sony Service or at the shop with best references for this kind of job.
Best regards,
Arpi
