How do you retrieve erased information off of your recorder
Unfortunately this recorder model is designed with flash memory and once the files are erased they are gone. There are some companies that do specialize in flash memory recovery (Olympus is not one of them). You can go to google and search for flash memory recovery specialists. However this is a very costly process as it involves sending the device to these companies for them to do the recovery process.
Hello you can erase the recorded messages one by one or all massages in folder at time
Note once a recording has been erased, you cannot retrieve it.
Erasing messages one by one
1 Press ERASE while playing back the massage you want to erase or press ERASE for more than 1 second during stop mode.
A beep will sound and the message number and "ERASE" will flash while the first and last 5 seconds of message is played back 10 times
2 Press ERASE while the message is being played back.
The message is erase and the remaining messages will be renumbered. (For example, if you erase Message 3. When erasing is completed, the unit will stop at beginning of the following message.)
Erasing all messages in a folder
1 Press FOLDER to select the folder you want to erase.
2 While pressing STOP, press ERASE for more than 1 second.
"ALL ERASE" will flash for 10 seconds
While the display is flashing, press ERASE.
