HOW TO REMOVE BACK COVER ON TIMEX EXPEDITION WATCH
If caseback is without grooves, it is snap on caseback and you have to insert openers blade under the lip and pry up. Lip is the tiny gap between the case and caseback.
If you have groves in caseback, it is screwdown caseback and you will need special opening tool. Insert the blades in to the grooves and unscrew the caseback.
You can find this tool on eBay.
Rate, please.
SOURCE: watch battery replacement
I used a modification of the vise solution. I put a plastic bottle screw cap on either side of the watch (bottle side in) and tightened the vise. I heard a satisfying "pop" and I am on my way. Fred
SOURCE: how do you replace the back cover on a Timex
mcdevito75 here, Look for any indentations on the back cover and case that should be linned up, as an example, a cutout on the cover for the stem, after the cover is linned up place the watch on a sturdy surface crystal up (glass) and with the palm of your hand apply even down pressure to close the back. If you can"t look for a small watch repair shop, they will close the back cover for you.
