I have paslode finishing nail gun , i cleaned it, not working now
I have paslode finishing nail gun , i cleaned it and then i tried to use it , but it is not giving the full bang. it is smokey as well and will not drive the nail fully into timber, now this is not the first time i cleaned it , so i am very annoyed about it. it will now not let the firing pin go back up into chamber by itself , i have to manually do it my self , if u can help me i would be very gratefull thanks .
Re: i have paslode finishing nail gun , i cleaned it, not...
The smoking is normal for a few times after cleaning ,but you might have put to much oil drops in chamber and piston chamber is getting a "vapor lock". Try recleaning with degreaser. Also have you forgotten to set the depth gauge at front of nose.
Have all the nails been cleared out of the tool where they were jammed? If not take the fuel cell out of the tool, and remove the battery before working on it. If still persists come back to this website for further help.
<p><b><i>Paslode cordless nailers</i></b> are a very common tool used by many professionals and do it yourselfers. These <b>nail guns are a great tool</b> when they work correctly, but can drive you nuts when they do not work as they should. When answering problems that people have on <a href="http://www.fixya.com/"><b>www.Fixya.com</b></a> I come across many questions about these nail guns and why they do not work.<br />
<p><br />
<p>If you are having problems with your <b>Paslode nail gun</b> the first thing you need to do is get the <b>Paslode manual</b> out of the box and checkout how to <b>clean the nail gun</b>. One of the most common causes for these <b>nail guns to have problems</b> is because of a<b> lack of maintenance</b>. If you do not have the <b>manual for your Paslode nailer</b> you can download one here. <a href="http://www.paslode.com/owners-manuals.html">www.paslode.com/owners-manuals.html</a><br />
<p>They have all of the current models and also <b>discontinued model Paslode manuals</b> there.<br />
<p><br />
<p>The manual will also contain <b>troubleshooting information</b> also. The <b>troubleshooting guide</b> can often help you to find the problem with your tool. Do not do the common man thing and be too proud to <b>get out the directions and READ them.</b> There are many tips and helps contained in them that will save you a ton of aggravation later.<br />
<p><br />
<p>Now, there are a few things that I have found out through my experiences with this nail gun that are not in the manual. <br />
<p><br />
<p>First, When the manual tells you that the tool needs to be <b>cleaned and lubed regularly</b> it means that you NEED to do that. Most problems are because of a<b> lack of cleaning and lubing the tool</b>.<br />
<p><br />
<p>Besides that, <b>gas cylinders</b> are a problem sometimes even if they are new. If you just replaced the gas cylinder and the <b>nail gun will not work</b>, try another one. Also, sometimes the end that goes on the gas cylinders will not snap on correctly or completely. You sometimes can still get the cylinder into the gun but it will not work because the top is not attached completely or correctly.<br />
<p><br />
<p>Check that the <b>nails do not get jammed in the magazine</b> and then not push up to the front of the gun. No nails, no work. Paper from the nails can sometimes cause them to bind up and not slide front. Make sure to always use nails that are only for the<b> Paslode nail gun</b>.<br />
<p><br />
<p>The firing pin can also be a problem. The <b>firing pin will bend</b> sometimes, but usually because of lack of the right nails or maintenance. Another problem that can happen is that the<b> o-rings around the firing pin</b> will break or crack. When this happens the gun may not fire or the pin will not return after it shoots a nail. If you are having these problems then check the o-rings both top and mid-pin to make sure they are in good shape. If they are chipped or cracked in anyway the gun will not work correctly.<br />
<p><br />
<p>The <b>battery contacts</b> on these nailers are also a problem. They can get dirt and dust in them or become bent. If they fail to make good contact they can cause the gun to have all types of problems. If you are having unexplained problems then<b> check the contacts of both the battery</b> and the gun. You can clean them with a soft cloth or sometimes with a pencil eraser.<br />
<p><br />
<p>The last but least likely problem is the<b> internal wiring in the nail gun</b>. Because of the violent nature of the gun firing the wiring takes a beating inside the nail gun.<b> Every time the gun fires</b> the vibration can cause the wires to move just a bit and eventually a wire can work loose. If all other things check out then look for wires that do not go anywhere. If there is a wire floating around that has no home then you have found your problem. After adjusting the end of the wire so it is tighter, reconnect the wire and you will be working again.<br />
<p><br />
<p>As you can see there are many things that can go wrong with these nail guns. Because of this there also are many things that you can find online that will help you. <b>E-how.com</b> has some tips that will help. <b>You-tube</b> also has some videos that will show you how to clean and troubleshoot these nail guns. Doing a simple online search will give you many places that can help you and also give you sites from which to buy parts if needed.<br />
<p><br />
<p>If you need parts for your nail gun, here is a good place to get those parts.<br />
<p><br />
<p><a href="http://itwconstructionparts.com/xcart/">http://itwconstructionparts.com/xcart/</a><br />
<p><br />
<p>
is the cylinder really dirty, if so it needs a thorough cleaning. your instruction mnual detailes how to do this. also look for a jammed nail in the nose area and possibly a bent driver.
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
which one?? or you can try and go to Paslode.com with your model number and see if you can download a breakdown for this tool along with cleaning instructions.
try a new battery m8 when they have been used fir a while they wear out at the catch and when u fire the nail gun the battery works its way out enuf to stop it making a good contact. Hope this helps.
Use the Paslode cleaning spray (Lowes and home depot stock this) Detailed instructions can be downloaded from the paslode site. http://www.paslode.com/owners-manuals.html
