I have a kenwood KDC-u346 car player, and I have this problem that started a month ago. Whenever I add new mp3 files or modify and save existing mp3 files, the player does not detect these new or modified files. Its as if it is stuck in its condition a month ago. I have tried ejecting the usb and re connecting it but the problem persists. I tried the same USB on other car players and they can detect all the mp3 files. I really don't know what is going on.
SOURCE: CD player Kenwwood KDC-129
1 kenwood KDC-129 manual as requested: http://www.kenwood-electronics.com.my/imanual/KDC-229.pdf
SOURCE: kenwood MP4029 4 code reset
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
SOURCE: need the wiring schematics
http://www.sirius.com/pdf/manuals/KCA-SR50.pdf
find it here in this manual
SOURCE: kenwood kdc-mp238
I have the MP-283 Model and the directions are poor not doubt,
I too was also having trouble with the DEMO mode and clock adjustment.
I put the stereo in standby mode, then press and hold the control knob for 2 seconds, then release and press the bass boost/ menu button, this shold open up all the options of the setero by using the control knob up/down to scroll through the various adjustments.
SOURCE: Kenwood KDC-MP438U "USB ERROR"
IF YOU DID NOT PRESS THE RESET BUTTON NEX TO THE USB PLUG, DO IT. IT WILL REINITIATE THE DEVICE TO THE FACTORY; YOU WILL HAVE TO ADJUST THE CLOCK.
I DID BECAUSE IT WAS WORKING AT FIRST.( PAGE 3 OF THE MANUAL)
CLAUDE
