Question about LG Shine KE970 Cellular Phone
LG VU does not recognize my blue tooth while trying to pair two
LG vu does not find my bluetooth headset while trying to pair the two. does not reconize my blue tooth
  • muffmin Apr 30, 2009
    LG Vu does not recognize device when trying to pair with BlueTooth
Help my pair my bluetooth with my LG shine phone. I have a jawbone bluetooth.
Posted on May 11, 2009
6ya staff
SOURCE:
My lg prime will not pair with my jabra bt3030 bluetooth headset
you have to make sure your blue tooth device is in discovery mode most devices you just hold the power button for 6 to 10 seconds when turning it on,if you have it in discovery mode they will pair and you will be asked for a pin or pairing code ,most blue tooth manufactures use a 4 digit code they are as follows 0000,1234,1111 or 9999 i hope this helps
Feb 21, 2011 | Jabra BT3030 Bluetooth Headset
I need the passkey for a Lg-230 blue tooth headset
Most blue tooth manufactures use a 4 digit pin or pairing code you first must discover your device you have to put the device in discovery mode once you have done all taht and you are asked for the pin or pairing code they are as follows 0000,1234,1111, or 9999 i hope this helps
Feb 20, 2011 | LG HBM210 Bluetooth Headset Wine Red Color
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I am unable to pair my motorola blue tooth with my LG Wine
You must enter the default Bluetooth pairing code, on your phone, when prompted. The code is 0000 (four zeros).
For your reference, the brand of a Bluetooth device has nothing to do with compatibility. Bluetooth Corporation licenses its technology to many other companies. Devices using Bluetooth technology must conform to the Bluetooth standards. So, a Motorola Bluetooth device will definitely pair with your LG phone, or any other brand of phone supporting Bluetooth device communication.
Jan 25, 2010 | OEM Systems Bluetooth Headsets - Model...
User manual for LG HBS-110 bluetooth headset
To pair the headset with your phone:
Turn on the headset. Then turn on bluetooth in your phone and search for bluetooth device.
When your headset is detected, just select it and follow onscreen instructions to pair it with your phone.
Jun 08, 2009 | LG HBS-110 Wireless Headset
Lg env v pairs with jawbone but won't connect. is it the code?
I have had the same issue with MY Samsung bluetooth headset.
Here's the sequence that works for me:
  1. Delete the headset under the bluetooth menu.
  2. Turn off the bluetooth
  3. turn on the blue tooth
  4. Add the headset back. The default pair code for most devices is "0000" or "1234"
  5. Try to enable/connect. If it fais, simply power off the enV.
  6. Power on and try to connect again (just connect, not pair)
  7. Headset will then pair.
KingGypsy in Phx.
Jan 19, 2009 | LG enV VX9900 Cellular Phone
I have somewhat of a solution. when you go to www.att.com/BluetoothWizard, it will prompt you to put in the handset Make & Model and then proceed with the Make/Model of your Bluetooth. It is possible that your Bluetooth headset may not be compatible with the LG Vu.
Dec 09, 2008 | LG Vu CU920 Cellular Phone
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
LG Shine KE970 Cellular Phone Logo
507 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
Sheldon Dedek
sheva420
sheva420
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
