Wc xerox 420 creat u9 code please resolve
SOURCE: Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
SOURCE: Rank xerox 5328 U9
if its a u9-1 code it is the lamp that is faulty. Sometimes it can be the connections either end of the lamp but normally the lamp itself. It will probably cost as much to fix as it would to get a new one to be honest
SOURCE: WORKCENTRE PRO 420 U9 CODE
Hello sir; The U-9 code means the main control unit/switch board problem, replace it.
SOURCE: xerox u9-5 code on a 5028 copier
Hello sir; There is a reset procedure require;
hold down 0 while you turn on the power, then enter 20 press start enter 3 press start. turn power off and on.
