Nokia 5130 not working it open comes white screen
Do you hear any sound?
If yes, then it means that it started up but the LCD display is broken and should be replaced. In that case, you should take it to a GSM service if you don't have experience.
If no, then maybe there is a firmware related problem. This is a little bit difficult for the inexperienced user to fix and again, you should take it to a GSM service to fix it for you.
SOURCE: my nokia 5130 frezzes and switch off after a
my nokia 5130c-2 show contact service when switching on
SOURCE: nokia 5130: blank screen, phone doesn't turn on
That means your phone got a corrupted software installed to its memory. A hard phone reset can solve this problem. Typically a nokia symbian series phone can be formatted using this code *#7370# then the default key is 12345.
Hope this could help.
Testimonial: "yes, it did get corrupted by a software and I had to give it to some workers at nokia to fix it, I lost the info on the phone (except memory card)"
SOURCE: Nokia 5130 music express mobile
If the incoming and outgoing is working properly try to change the lcd.10000000000...% OK.
Flashing is the only solution, but anyway Remove Memory Card,Sim Card and reboot by inserting only the battery.Try it for 2-3 times.If the problem still persist better to contact mobile repairing shop or follow this trick.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 5130 flash file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment. thanks for visiting fixya. Good luck.
