How can I remove the stand on this TV in order to mount on the wall? The only screws I can find are on under the stand and after removing them all the stand just wobbles about but will not detach from the TV
To disassemble it, you have to see some illustrations. If you wish to get more details about how to disassemble Toshiba TV, check this link. http://electronicshelponline.blogspot.com/ Pull up older posts there. Disassemble procedure to many TVs are given in detail, with illustrations.
SOURCE: How does one remove the Toshiba TV stand.
ya we put four screws in the base of the stand you have to lay t.v. on a flat surface protect the screen from getting damaged by putting a blanket over it when u flip it over or lay it flat on the bed you will see the 4 screws that hold the base to the t.v., but if it's a model that's having trouble just leave the base on as you will probably be returning it the store where you bought it lol
Testimonial: "Thanks for that - will try it!"
SOURCE: stand
3 or 5 scews at the back of the set just above the stand . remove these then 2 persons lift the tv straight up leaveing the stand behind. you will the have to lay the tv flat or put it straight on the wall
thats if you have fitted the wall brackets of course
SOURCE: I have a 52in Toshiba flat screen that I want to
Check carefully with a flashlight to see if you removed all the screws completely. The stand should pull out quite easily as long as all the screw are out on the back bottom center of the TV.
SOURCE: i want to remove stand from 42 to hang on the wall 1080
Click here to download the user's guide and check page # 5 for instructions on how to remove the pedestal stand.
