Question about Anti-theft Alarm System 3 Series E90 E92 Bnib
Why is my abs lights on whiles all sensors and brake fluid level ok
The abs lights is on
    New Friend:
  • 153 Answers
You probably have a faulty wheel sensor, these can be checked to determine which one.
Posted on Oct 28, 2013
Anonymous
SOURCE:
Trouble connecting back to Randy. aBS light is on. Parking brake switch ok. Brake fluid level ok
Check all 4 ABS sensors on the wheels . possible wire is damaged or bad contact in the plug to the Sensors.
Apr 08, 2016 | 2003 Kia Sedona
Abs and brake lights are on
If both the RED brake light and the ABS light are coming on while you are driving the car, you either have an hydraulic failure or there is a problem with your ABS module that can potentially affect your regular service brakes.
The first thing to do would be to check the fluid level in your brake master cylinder. If it is low, you need to find out WHY. There is always a reason for the fluid level to be low. It is NOT SAFE to just add fluid without correcting the problem that caused the fluid level to be low.
If the fluid level is OK, then you must scan your antilock brake module for fault codes. The antilock brake module controls the antilock light and can affect the RED brake light as well. There are many different possible failures that can cause this. There is NO OTHER WAY to know why the antilock module has turned the light on. You can spin your wheels for days, replace a BUNCH of parts and never find the problem if you do not scan the module first.
Dec 08, 2011 | Cars & Trucks
My brake and anti brake lights stay on all the time
CHECK ALTERNATOR OUTPUT IT SHOULD BE 13.5 TO 14.5 VOLTS WITH ENGINE RUNNING.IF VOLTAGE LOWER 12 VOLTS THAT WILL CAUSE BRAKE AND ANTI LOCK BRAKE LIGHTS TO COME ON BECAUSE THAT NOT ENOUGH POWER FOR ABS BRAKES OPERATION.IF ALTERNATOR GOOD.BRAKE AND ABS LIGHTS ON ALSO MEANS LOW BRAKE FLUID LEVEL CHECK BRAKE FLUID LEVEL.ALSO. YOU HAVING BRAKE FAILURE.YOU NEED TO HAVE GARAGE OR DEALERSHIP CHECK BRAKES SYSTEM.BEFORE BRAKES COMPLETELY FAIL.
Mar 23, 2010 | 1991 Dodge Dakota
Hi i have a saab 93 1999 2lt se with both the brake and abs warning lights on, ive had new pads allround checked fluid level fuses connections to abs pump etc all ok checked connections on abs ecu all...
i know this may sound strange but remove the brake fluid cap. on the cap is a sensor, do this away from any other vehicle and yours and shack the sensor by the cap a good few times. as fast as you can. then re fit the sensor see if the lights go off. sometimes it works sometimes not. this just because the brake light is on, this only usually comes on when the sensor thinks there is low brake fluid. and it can also tell the abs as well. and this is why both the lights are on. also make sure the fluid is at full markings.
Jul 03, 2017 | Saab 9 3 Cars & Trucks
Abs light say on and breaK LIGHT
check your fluid level, and pads if good it could be a bad abs sensor
Jan 16, 2010 | 2002 Chevrolet Malibu
ABS light stays on.
check your abs plugs on the top of you master brake cylinder.most of the times it turns out to be just a loose plug.
check and keep updated.
thanks.
Jul 08, 2009 | 1999 Isuzu Rodeo
ABS/Brake dash light on 2004 Chevy Astro rear wheel Drive
Look for wires hanging, near the tire area under the car. An ABS sensor wire may be broken or the sensor is damaged.
Getting the system scanned will tell you exactly what is going on.
Jun 19, 2009 | 2004 Chevrolet Astro
Mini cooper Warning lights for abs, low tire,traction comes on
Ok, check the brake fluid level for a start. This could mean a few things. Your brake pads might be worn down, which would bring a yellow warning light on(triangle), at the same time with the pads being low it will have displaced the fluid, making the level low, this would be a red light on. Now because of this the body control module has detected these faults, will have turned the abs off, hence the abs light.
If brake fluid is low, this could confirm my theory.
If its low, top up with dot 5 brake fluid and take to garage to have new pads fitted.
TL
Jan 24, 2009 | 2007 Mini Cooper S Convertible
1998 Chevrolet Malibu -- ABS and Brake light on.
If when changing the brakes you pushed fluid back into the master cylinder it may have affected the abs sensor with the reverse flow. I have seen this happen before.
Oct 19, 2008 | 1998 Chevrolet Malibu
Anti-theft Alarm System 3 Series E90 E92 Bnib Logo
150 people viewed this question
Top BMW Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Marvin
Marvin
Jonah Oneal
Are you a BMW Vehicle Part and Accessory Expert? Answer questions, earn points and help others
