Air compressor
Usually, motor will draw lower amperage when tank is empty then draw most when about full. High amp draw is caused by long cord, weak capacitor, leaking check valve or blown head gasket/s. If gaskets are bad, the head of the compressor will be very hot and take much longer to fill. If the motor (is too small) is not correctly matched to the pump, the motor will draw max amps. To correct motor to small, use a smaller pulley at the motor. Using a smaller pulley will turn the pump less rpm giving the motor a break lowering amp draw. Good luck
