Is this a Miele dryer?? and a condenser 'C' at the end the model number?...If so, the contstant beeping it telling you there is a fault. Possibly airways blocked. Take out the heat exchanger and flush it out with hot water. The heat exchanger is a fairly big aluminuim box located behind a pannel on the front left hand side of the dryer.
You should open the service panel and to find out where does the "beeping" unit located and to remove one of the wires connected to it (the unplugged wire should be insulated). Good luck!
i bought a dryer 2 weeks ago its a LG and i turn it on after a few mins its goes off beeps and then in the screen lel shows up and it wont start agin
I have SAME problem. Just flushed out the aluminum box as Mr Miele suggests but it still contunies to beep. Does the whole aluminium box have to be completely dry before putting it back into the machine?
