I just bought the Panasonic SC-PT660 surround sound home theater and i was wondering if there is anyway to hook up my blu ray dvd player to it so i can watch movies in better quality.
Why not leave the audio into the TV via HDMI from the Bluray and then optical audio out from TV to the home theater audio system? Same as the hook up for the cable box. The SC-
PT660 only has one optical audio connector so your solution may not be feasible assuming he's also got a cable box connected to the TV.
As far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Need help with connecting the system so that it can be used as a surround sound when not watching blu-rays
Need to find out how to get surround sound to work from the tv when not using the blu-Ray
Player will not play all blu rays. To date it will only play avatar and titanic all other blu rays just freeze on a black screen.
