Water Sport Logo
Mel Hansen Posted on Jun 11, 2013
Have a 1999 yamaha 1200 xl wave runner when try to start nothing happens except start button lights up
Put PWC in lake started right up went around lake several times beached it for about 15 minutes tried to restart wouldn't start put in new battery still won't start just the start button lights up. Just had engine rebuilt last spring
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jul 16, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
Helped
993
Points
27
Mine was doing the same thing it was the starter solenoid,may also be the starter if the motor does not crank over
  • Mel Hansen Jul 16, 2013
    thanks that's what we are in the process of replacing so here's hoping that's all it is :)
2 Related Answers
Anonymous
  • 207 Answers
  • Posted on Jul 08, 2009
SOURCE: how do we start a yamaha 1998 xl 1200 wave runner
first put a new battery in it. then put your lanyard in the handle bar clip push the start button make sure that you have a life jacket on when your in the water and make sure that u attach the lanyard to your wrist or life jacket
protek480
Craig Butler
  • 1730 Answers
  • Posted on Aug 29, 2009
SOURCE: 95 yamaha wave runner starts
Have you changed the 'fuel filter'. That's where you start.
If you need further help, Iā€™m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
I have a starting problem with my 2005 Yamaha XTL 1200 jetski it turns over but wonā€™t start I took out the spark plugs and cleaned them they were black but still wouldnā€™t go
Black plugs indicate carbon build up. Try starting with ether sprayed into carburetor. If it fires, clean fuel system with spray and additive. Use the fuel engine was designed for.
2answers
What is wrong with my wave runner
Make sure you are using Yamaha oil not an off brand. It does make a difference.
2answers
Yamaha torque specs
The owners manual does not provide torque specs there is an on-line manual for $5 which claims to cover torque specs at: https://www.tradebit.com/filedetail.php/141315359-yamaha-waverunner-gp1200r-service-manual-repair-2000-2002
1helpful
2answers
How to fix a water port?
possible seized water pump
the one that is not working
follow it back to the source look for blockages
but personally i cannot see a blockage stopping all water coming out
so i would look more at the water pump
Yamaha 1200XL PWC won't start
hi there could be corrosion on the switch gear and kill switch check and clean as well as the wires going tostarter soliniod,corrosion on these electrical connections are always a problem cheers pete
1999 Yamaha wave runner 1200 XL won't start
Check to see if you get power to the starter when you try and start it. If you do, they you may have a bad starter. If not then you may have a bad switch or even blown fuse.
Jun 11, 2013 • Motorcycles
1999 Yamaha 1200 XL won't start only start button lights up
Please repost this in the section for motorcycles.
How do we start a yamaha 1998 xl 1200 wave runner
Top Water Sport Experts
ADMIN Andrew
ADMIN Andrew
johnny bonacci
johnny bonacci
Are you a Water Sport Expert? Answer questions, earn points and help others
