est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode
and capacitors can br tested. The capacitor must bealloweddischarge
before testing, or you risk to get electrocuted, evenifpower is off.
Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here:
Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts,
contact the seller here to purchase parts.
same problem, microwave was fine then just started taking about 3x longer to heat or warm anything. it is clean so that is not the problem,, what else could it be?
