i was formating my mp3 player when my daughter unplug it and know i cant get it to work at all or bring it up on the computer i was formating my mp3 player when my daughter unplug it and know i cant get it to work at all or bring it up on the computer
You can't post conmments that contain an email address.
Http://www.lenoxx.com/2005/mp3player/mp556.htm
if you have a ilo model mp-556 (on the back cover) this page has links to the firmware ... i follow the instruction and got mine working.
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer. You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
For that you will need a PC/Laptop with USB port.
Connect you player to it, wait until: found new harware ILO MP3 player ...new harware is successfully installed and ready to use. After that the window will pop up: you will need to click:open folder to view files. If no window will pop up, click my computer, find the ilo MP3 player, double click.
After that you can copy your songs (in MP3 format) from any source and insert them to you ilo MP3 folder ( it might have a subfolder, called songs) and you are good to go.
Good luck
Try starting from scratch.
Right click the drive and choose Format-> FAT32,->QUICK Format->Start. This will only take a few seconds.
Reload your music.
Go to My Computer IlO or name of player music and
copy/paste your files in that directory
My Computer/ILO/Music/
Do not use Media player and do it manually and it should work (any computer)
Through
this link, you can enter a variety of search terms that will help you
find what you are looking for (exs.: “add files to my mp3 player”;
“delete files from my mp3 player,” etc.)
Important Vocabulary:
The code word for “mp3 player” in Windows Media Player is “DEVICE” or “portable device”
The code word for adding files is “SYNC,” “syncing,” or “synchronizing”
The code word for copying files from CD is “RIP,” or “ripping”
The code word for files stored on both My Computer and my Mp3 player (when it is connected to the computer) is “LIBRARY”
To add files (SYNC) to your mp3 player using Windows Media Player 10:
When you use an mp3 player on 2 different media players, it causes a format change when connecting to one or the other. Stick to one media player only.
Ok I have same player, same problem. Turns out Windows Media player copied the files into the FM subfolder on the device.
FIX:
connect device to computer. Do not open WIndows media player, instead open windows explorer, in there you should see the ilo as a new drive. Click the drive and go into the FM folder, now select all files and drag them directly to the drive. The secret is the files have to be outside of the FM folder loose in the device (not in any folder)
After that I safley removed the device from the system tray icon and powered it on and the songs were all there. It runs an index process that creates the lists, this takes a second.
