Lionel Refrigerator Truck/trailer, O/027 Logo
Anonymous Posted on Jun 10, 2013
Service manual for Thermo King TS 500
I am looking for a diagnosis manual to explain the repairs necessary for alarm codes on TS 500 refrigerated truck
  • ravnil kumar Mar 21, 2019
    Can you tell me the error codes
Kardoc
Level 3:
Top Expert:
  • Master 7,503 Answers
  • Posted on Mar 21, 2019
Kardoc
Master
Level 3:
Top Expert:
Answers
7503
Questions
0
Helped
2758943
Points
58323
Gooday all, my name is Jerome and I'm from Namibia Africa. I have a Thermo King T600 and it's giving a code 35. The engine is not even cranking even if I clear the code. Any help please?
Question edited for clarity.
Code 35 is for the microprocessor on the unit. There are software updates to help repair the units. You will have to test the board to make certain there are no problems with the unit.Dec 17, 2019
Code 35 check run relay circuit on my thermoking. Ts500
More here
https://www.google.com/search?q=thermo+king+T600+code+35
How to clear a code on a thermo king fridge unit sb111+sr
https://www.google.com/search?sxsrf=ALeKk03UXpuDOwrs3FOUigUwAHemZ5200g%3A1584695714864&source=hp&ei=ool0XszVMu-KjLsP46O2iAU&q=How+to+clear+a+code+on+a+thermo+king+fridge+unit+sb111%2Bsr&oq=How+to+clear+a+code+on+a+thermo+king+fridge+unit+sb111%2Bsr&gs_l=psy-ab.3...2328.2328..3075...2.0..0.473.473.4-1......0....2j1..gws-wiz.....10..35i362i39.I7Ztk2OZ8M0&ved=0ahUKEwjMrqPJ26joAhVvBWMBHeORDVEQ4dUDCAU&uact=5#kpvalbx=_Zox0XvmOLY2f1fAPuIK3yAI36
What do I do to fix code 20 on my thermo king sb111 whisper edition refrigerated trailer
driver just call your local thermo king wherever you are and they will help you asap tell what the code 20 is and how to fix it.
Mike
T600R thermo king alarm Code 10 High Discharge Pressure
Helo sir I have a thermo king t600 code 10 or 42or 84 its can ciler
1helpful
3answers
We have been getting service code 50 for our SubZero -- it;s a 690 model fridge/freezer. I cleaned everything however over last three weeks the error repeats. I reset the board by pulling power from the...
Error code 50 means excessive refrierator section compressor run. Possible causes include: dirty condenser, stopped condenser motor, faulty termistor or an evaporator refrigerant leak. If it is a refrigerant leak it usually shows up as frost or water driplets half way down on the back wall. Clear codes by holding the alarm button in for 15 seconds.
Top Lionel Crafts & Hobbies Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Carolyn Rogers
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
