Question about Panasonic KX-TG2356 Cordless Phone
Panasonic Phone Keeps De-Registering
Hi, I recently purchased a Panasonic KX-TG8032 cordless phone and it keeps de-registering, rendering itself useless without re-registering. It has got to the point that it de-registers itself straight after I re-register it (I haven't even had a chance to put it back on the cradle). The period of 'registration' has slowly decreased, from a couple of days to this. This problem has occurred for several different phones already, and I'm wondering if anyone has any ideas about what the root of this issue could be. I just find it a little strange that both phones are faulty. Furthermore, this has been our 6th phone this year, as each one either cuts off while we're talking or de-registers. Please help! :) Thanks :)
    Habit-Forming:
    New Friend:
  • 17 Answers
This solution is for the KX-TG2356 cordless phone
The problem you are having is not that the handset is de-registering but your handset is losing the link to the main base.You said you went through 6 handsets then, the only remaining thing that could cause your problem is: A bad handset battery. This would give you all types of connection problems and the Main base.
I will begin with replacing the battery. If that does not solve your problem then the problem would be the main base
Posted on Apr 19, 2017
5 Suggested Answers
Anonymous
  • 30 Answers
SOURCE: panasonic kx-tg7120e extra hand set.
with the hand set on the base, unplug the power then try plugging it again.
Posted on Jul 24, 2008
Anonymous
  • 11 Answers
SOURCE: I'm trying to integrate a
you cant ..dont try ,,coz it have integrating problem in Panasonic Cordless Phone KX-TG1811AL ..hence contact coustmer care.,./,
Posted on Aug 26, 2008
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: Registering a new cordless handset
It doesn't exactly "register" but you turn it on via phone programming.
Just plug it into the headset jack, then select a button to program and press PROG (the button) and dial 67 enter.
When you press the button, the light will turn on and the display will say HEADSET ON. Pressing it again will turn it off.
Carl
Posted on Sep 28, 2008
gorbuz
  • 5 Answers
SOURCE: bought new phones kxtga110ex and want to register handset from kxa141es
I can send you a manual. Just email me on gorbuz@yahoo.com
Posted on Nov 04, 2008
Anonymous
  • 48 Answers
SOURCE: register hend set to base
Try the procedure on page 62 of the following PDF, and post your results.
http://www.conversationpiece.ie/download/KXTCD505.pdf
Posted on Mar 23, 2009
Can I get replacement phones (3) for Panasonic KX-TG6843B 6.0 3-Handset Cordless Telephone? This phone blocks up to 250 calls. If I keep the base, will I keep my blocked numbers.
The stored block numbers should be saved. The database is in the base's memory. Since the KX-TG6843 base can support a total of 6 KX-TGA680S handsets, you can purchase and register 3 new handsets. If needed, you can de-register the old ones from any working handset and then add even more. See page 35 of the manual, ftp://ftp.panasonic.com/telephone/om/kx-tg6841_mul_om.pdf . Additional handsets are available from Panasonic, http://shop.panasonic.com/support-only/KX-TG6843B.html , Scroll down to the Accessories section and expand it. Amazon.com also has the handsets: https://www.amazon.com/Panasonic-KX-TGA680S-DECT-Accessory-Handset/dp/B00BS4D2CU .
I hope this helps.
May 30, 2017 | Panasonic Lands Phones
A busy signal
Hi Kevin,
Sorry for being off line so long. If you have not fixed the problem already, I would try de-registering the handset 3 (from both the base and handset), then re-register it, it should re-register as HS 3, unless 1 and 2 are vacant. If that does not do it, de-register just the handset (not at the base), then re-register it to the base, it will grab the next sequencial intercom number. If it is still failing, then the handset is most likely defective. As a last resort, you can try initializing the handset and the base. Let me know how it goes. CG
Apr 03, 2008 | Panasonic KX TGA400B Cordless Expansion...
DeRegistering a Damaged Cordless Phone????!!!!
If you are still looking for an answer on dereg of a handset, the manual says Menu - 0-0-2 then 3-3-5-OK then select the handset you want to cancel/deregister
Nov 05, 2007 | Panasonic KX-TG6074B Phone
DeRegistering a Damaged Cordless Phone???!!!!
I have a Panasonic KX-TG6700 base unit and KX-TGA670B handsets. We had a similar problem where we were no longer able to deregister the handset using the handset itself. We wanted to be able to use that slot that the broken phone was still occupyng. The solution that we found in the manual online was to hold down the intercom button for 3 seconds until the "in use" light turned on. Then press and hold the number of the extension you want to deregister until it beeps. At this point the base unit has freed that extension.
Nov 05, 2007 | Panasonic KX-TGA600B Cordless Expansion...
No Link to Base
to re-register the phone, hold down the "handset locator" button on the base untill he "charge" light flashes. then, on the phone, hold down the flash/call waiting button until the LCD screen says "handset registering." if after it registers it says "error!!!" then retry. that is what it says in the instructional booklet, but i have not done this successfully. mine keeps saying error.
Oct 22, 2007 | Panasonic KX-TG2313 Cordless Phone
Move closer to base
Either the phone is not registered to the base unit or the RF module is broken. It could be a bad battery but unlikely unless very old or you have not charged it. You should check the manual for registering the phone to the base unit.
Sep 07, 2007 | Panasonic KX-TG2584 Cordless Phone
Restting the phone handset number
I would suspect that you need to de-register both 3 and 4 at the same time before re-registering them. This probably will not work if the base unit still thinks phone number 2 is out there somewhere. It would need to be de-registered as well for the others to move up a notch. I did read the process for de-registering somewhere on the web, don't remember where, just that it involves removing/installing the battery and punching some buttons.
Jul 28, 2007 | Panasonic KX TG1000N Cordless Phone
Panasonic KX-TG2356 Cordless Phone Logo
115 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
