OLDER ZENITH TV MODEL NUMBER SG2516TR HAS ROLLING VERTICAL LINES AND I DO NOT KNOW HOW TO ADJUST IT. CAN SOMEONE TELL ME HOW? TV HAS A NEW PICTURE TUBE AND EVERYTHING WORKS GREAT EXCEPT THE ROLLING LINES. I CAN SEE MENU AND ADJUST TINT COLOR ETC. DOES ANYONE KNOW ANYTHING ABOUT THIS?
SOURCE: vertical flickering color lines instead of pictures
Soory man there is no deflection yoke or vertical output IC in a plasma TV set.LOL This person has a problem with whats called the substain power supply or bad caoacitors in the main supply. there is also a possibility that the set has a bad tuner. Only performing test on the set will determine the problem.
SOURCE: Zenith LCD Flat Screen TV just shows vertical lines of color
Press menu button on the TV if the on screen display is also distorted or no pic the TV is definetely defective. You can try unpluuging from wall for about 15 minutes and see if reset helps if not problem is either main p.c.b , LCD panel , LVDS cable or Power supply board. and would require service. most likely problem would be bad connection at or defective LVDS cable that connects main p.c.b to Panel (cheapest fix) or defective main p.c.b. If it is the panel it would probably not be worth repairing and you may want to sell as is on ebay.
SOURCE: My picture has a green and blue hue to it.
After spending a day trying to fix the TV, I found out the problem was actually with my cable box. I have an HD DVR recorder. We unplugged the cable box and plugged the TV directly into the cable in the wall and it worked. So we took the cable box back to our cable company and got a new cable box. (Can't live without the DVR!!)
SOURCE: Sony T240HD monitor TV
make sure that the plug on ps2 is connected and check the settings on tv and the settings on ps2 browser are correct if possible check ps2 on another tv to be sure of it's settings if the ps2 works the check channel setting on tv make sure it's not in pal setting it should be ntsc and also check the antenna setting make sure it might be set to cable and also check cables of any sharp kinks your problem is with the yellow cable red and white is the sound
SOURCE: Vertical lines in picture
The machine is still under warranty from samsung so I would call 1-800-samsung to find the nearest service center. Problem could be caused by a bad main board, bad lvds cable or a defective t/con board or lcd panel.
Testimonial: "Thank you so much for the prompt reply, it was very helpful! "
