Question about HP Pavilion Computers & Internet
Devices not found on laptop
The comp doesnt recognize or even find my cd/dvd rom or my webcam and they are both internal devices. i can put a cd in the drive and it spins at first ,then stops so i know its getting some kind of connection, but to what point im not sure. ive tried all i know to try i'm at a lose can anyone help
  • HP Master
  • 5,627 Answers
No PC state, make HP model, LT or Desktop.
no OS stated windows, what XP>? XP loves to hate CDs
it is INFAMOUS for that... and worse if upgraded the drive.
id bet this,
1: running sticking XP, and XP is a dead product at MS. and HP.
2: someone installed MS disks to it and lost the HP driver.
The HP drivers must be installed, for the cam to work
one USB driver and the correct camera driver to match you unstated OD.
The DVD drive needs this.
XP SP3, service pack 3 adds more drives.
then needs the (if XP ) patch to the registry called filter hack for XP DVD)
why even post lacking full model of HP and OS it runs
click start, click control panel click system.
bingo the OS name and version is there, if 64bit that too matters big time.
Posted on Jan 12, 2018
6ya staff
SOURCE:
SOURCE: laptop won't boot from external CD drive yet internal one is unresponsive
if you want to boot a cd e.g windows xp os disk then you have to go to the bios by pressing del or f2 or f8 ot f10 depending on the motherboard you use. try to find boot option -> boot priority or first boot device.if you find boot priority then select cdrom as first priority . if you find first boot option then also select cd rom. sometime if your disk is not bootable then it won't boot.
Posted on Jun 20, 2008
Curtis Richner
  • 461 Answers
SOURCE: cd/dvd rom not working on hp laptop
Is the Drive detected in the BIOS? Can you boot from your Windows or any bootable disc? If so try this solution:
Always backup your registry before editing and use care to find exact key!
Start Registry Editor (Start, Run and type in regedit then click)
Find "UpperFilters" and "LowerFilters" (and "UpperFilters.bak" "LowerFilters.bak", if they exist) value under the following key in the registry, and delete it:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Quit Registry Editor.
Reboot.
NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this.
Posted on Dec 17, 2008
Anonymous
  • 29 Answers
SOURCE: My cd rom drive will not recognize any cds or
When I had my problem, no cd was recognized, music or data. But when I paced a dvd movie in there, and started up my PowerDVD, it would play just fine. I ended up replacing the drive. In fact, I got an upgrade because the first one was CDRW/DVD-ROM, and now its a DVD burner. 86 bucks including shipping.
Posted on Mar 08, 2009
Anonymous
  • 76 Answers
SOURCE: cannot open cd-rom drive!
The thing about cd/dvd drives in general is that they die and thats the case here even if you deleted anything of the operating system its self would notice that the cd drive was missing the driver and ask you about it since you havent stated that its safe to say that the drive is dead
Posted on Mar 13, 2009
leecom72
Lee Hodgson
  • 4806 Answers
SOURCE: CD/DVD rom drive not working
Hi there.
It sounds like the drivers could be bad or the lens has gone.
This can be a common problem with vista loosing the CD/DVD drives.
Do this >>>>>> right click on "computer" and select "manage" from the sub menu, then select "device manager" from the left hand side, it will generate a list of devices, look down the list for CD/DVD and click on the + icon next to it, from the drop down list right click and uninstall, restart the PC and let vista re-install the drivers for you, then try to use the CD/DVD.
If this does not work please post back.
Good luck and thanks for using FixYa!!
Posted on Mar 16, 2009
Acer aspire 5740 DVD not recognized
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Check BIOS by pressing F key (correct F key is noted during boot) and make sure BIOS see's the Optical Drive.
Oct 25, 2012 | Computers & Internet
I have an Acer Aspire 5332 and the CD-Rom/DVD Drive (Optiarc DVD RW AD-7580S ATA Device) is not working properly...every time I put a disk of any kind (i.e CD/DVD/Game) it doesnt recognize it and load
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Mar 22, 2012 | Acer Computers & Internet
My compaq presario f768wm isnt recognizing my cd/dvd rom. my camera quit working and also it says it can't find my audio output device.
For that problem, Try first replace that internal DVD-rom drive other good internal DVD-rom drive. if not Also Detected or recognize.
Try this second solution. insert external USB type DVD-ROM. if not recognize also, Your operating system Have internal software device data corrupted. You need to reinstall operating System like windows xp, windows 7 (OS) etc.. to fix data Corrupted of operating system device for hardware software.
Please see sample external DVD-rom USB type.
Just let me know if not yet working your Compaq Presario 700 series DVD-rom Drive.
Thanks for using Fixya.
Aug 19, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
My pc doesnt detect my HL-DT-ST-DVD-RAM-GSA-H55N LG super multi dvd/cd-rom, i tried checking ide cables but still it doesnt read, i cant even see the dvd/cd-rom on device manager------there is no...
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Oct 31, 2010 | LG GSA-H55N DVD-RAM Burner
Hey guysi have a dell vostro1500my problem is with its dvd drive that doesnt recognize any dvd or cd.i reinstalled the drivers but didnt work.it doesnt even boot when i put a bootable dvd in it and try to...
You can try to refit it, take it out and put it back in, it may be loose.
I had to replace my drive when this happened to me, check ebay for a cheap replacement
Jul 19, 2010 | Dell Vostro 1500 Notebook
Lost cd driver so unable to update driver in device manager page.. where can found free download of that driver
cd driver ??? what OS u using ? what brand pc cd roms/dvd roms normaly install them self with windows drivers ?
Jan 27, 2010 | A4tech PK-635 Webcam
My acer Extensa 5620Z DVD/CD ROM drive is detected as USB mass storage that provides internet(Modem). When I remove the internet modem, the CD ROM is not listed in My computer. When I put CD or DVD in it...
That is a Vista problem with ACER. Delete the reference in device manager and restart and let the comp reco0gnize and reinstall ...just follow the screen instructions.
There is a registry setting that needs deleting but only if this doesn't work.
Nov 03, 2009 | Acer Extensa 5620 Notebook PC
Internal samsung cd-rom sn-124 doesnt recognize cd's/wont work
replace it. samsung cd rom even its dvd writer have lots of problems. sometime they dont want to open unless you leave a cd in it. sometime it doesnt read cd. better change it. get a Sony, LG, Pioneer DVD writer.
Aug 20, 2009 | Computers & Internet
Driver doesnt read disks or even work
try this  go to the device manager click on the DVD/CD rom drives and right click the options and then click uninstall
Now right click on the DVD/CD rom drives and then click scan for hardware changes
now open the cd tray and put and dvd.
Jun 10, 2009 | Acer Aspire 5500 5570-2609 Laptop
The cd drive does not recognize any discs
That is not a DVD drive, it is a CD-ROM drive. It can not play DVDs.
Jan 20, 2008 | Panasonic CD FOR TOUGHBOOK (cf-vcd721w)...
Computers & Internet Logo
44 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
