Panasonic Viera TH-42PZ80U Plasma TV Logo
Posted on Mar 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replace screen i have Panasonic Viera TH-65PZ850U with damage internal screen, i cant find that part, anyone help me find new screen? please
Anonymous
Level 3:
  • Master 4,234 Answers
  • Posted on Mar 22, 2009
Anonymous
Master
Level 3:
Answers
4234
Questions
Helped
1564563
Points
12312
This is a plasma panel and the part number is: MD65F10A1J and the cost is $3387.95 with a refund of $200 when the bad panel is sent back.
Dan
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 19, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
453
Points
Volume but no picture for panasonic TH-42PZ80U
I have a panasonic viera th-50px75u and i cant get
Try disconnecting all HDMI cables and plugging the TV into a new wall outlet. If the issue is resolved, it may have been caused by a small power surge from either your wall outlet or one of your source devices.
1helpful
Panasonic plasma TH-42pz700 has left hand side of screen distorted
The set uses two boards to drive the screen --one for each half or side.
Different names are used like sustain or in LCD sets inverter.
2helpful
2answers
NO POWER FOR A PANASONIC VIERA TH-50PZ800A
I would suggest you try different power points in your house to eliminate whether the cause of the problem is based on your TV.
If it is the TV check the cable for any damage. you can view more detailed information at http://www2.panasonic.com/consumer-electronics/support/Televisions/VIERA-Plasma-HDTVs/Operating-Instructions/model.TH-50PZ800U.O#ts
There is also a guide for the warranty of the unit.
Panasonic Viera TH-42PV60H displays vertical lines on left side of screen.\r\nThese lines flickers and changes colors. Initially was about 2cm wide and now it is about 4cm.
Either LCD transistor got moist or the video chipset got condensation. Keep TV on standby to dry it out. Unless there is also mechanical damage to the lcd screen on the edge..
3helpful
Panasonic Viera Closed Captions HELP
Just use he remote and push the cc button or the display button until cc off appears on the screen
Line in queens new york- have a panasonic plasma th-50pz800u craked front glass- still shows- looking to replace- anyone with contact numbers or web sites to replace glass. Thanks
try auction or surplus electronic sites buy a broken plasma screen tv unit ask the seller if the outer glass is good most like they only sell it if the inner plasma glass is broken try that sometimes this is the easiest way unless you want to pay full price and parts site..i do have a 42" front glass thats good but i dont know if this fits the 50". hope this help
Viera TH-65PZ850U
Without investigation it is impossible to know what failed. There are a number of boards in that set where there is fairly high current used. It is possible that some components have failed.
The Panasonic service rep would service the set by swapping out the failed modules. If the set is an older model the modules may no longer be available. You can take the set in for an estimate to see if the parts are available, and to see if the set is worth to service.
Jerry G.
Panasonic Viera Scratches help
The only supplier for parts is the Panasonic service rep and their parts distributors. To change the front panel transparent window is a fairly big job. In most models, the compete screen has to be removed.
You will find that the replacement window is fairly expensive. The labour would also be expensive because of the time involved.
What you should do is get it streight with your children to not touch the screen. Also, if they have allowance, you should cut if back by a fair amount for a long time to compensate for the damage.
Jerry G.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
