Ok so i did the xclamp fix, and did a clean job, but now it went from 4 red rings to 3 red rings. Then i did the towel trick to have it overheat, and i have the 2 red rings. After getting the 2 red rings i let it sit for a few hours and tried to turn it on again, and no dice, still 2 rings. Any ideas?
Yesh...4 red lights means you didn't have the component or hdmi pluged into the system and tv. 3 lights means there is some soldering problem in your 360. 2 lights means your 360 is overheated. For the 2 lights normally you can fix that with letting it cool for a while and give it some room around the system to run cooler. However by using the towel trick you you caused the soldering to run and now it's probibly miss soldered. I recommend you ship to Microsoft or sell it.
SOURCE: 2 Red rings
Do the x-clamp fix again making sure the chip is very clean. Then make sure when you set the heat sinks that they are perfectly flush on the chip but don't tighten them real tight about 3 inch lbs is plenty. Leave the "towel trick" for the drunken monkeys out there. If you havn't fried it google "Air Flow Box" or find it on ebay this will help air flow under your MB was well as air flow over the heatsinks. It will also make cleaning the heatsink easier with out cracking the box. The 360 has a very anemic cooling system you have to fight heat aggressively. The stock 360 gets so hot it can loosen the solder joints I guess so you have to do everything you can. I put the Air Flow Box in a new console with the Falcon board along with the extra heatsink on the video scalar chip. Why run something that is designed to overheat. A 40%failure rate is attributeable to poor design in cooling IMHO. Don't let me tell you haow to act but you have to fight overheating from the getgo.
