Our oven door was stiff and made a cracking noise when we opened it. Now the hinge on the left side pops out and the door all but falls off when we open the door. Also, the door does not close all the way, so when baking it loses a great deal of heat, and it is hard to judge cook times. We have had a local repair man look at it but he does not know what to do. Any help would be appreciated. Thanks
Hi
Please check the latching mechanism.Also check the spring attached to the door either of the two is broken and needs a replacement.Please let me know the model no.
Thanks for acceptin the solution . Please tell me the model no clearly so that I can provide you with the correct information.
Thanks
Rylee
Please visit these links for details---
Viking parts
Viking spring door
Also visit this link---
Viking ultra line parts
And regarding your hood you need to check---Check for an internal fuse
Check for the power coming to hood and also check the power circuit of the hood for loose wiring.
Thanks
Rylee
Oven door and door hinge help....
Oven door and door hinge help: There are There are way too many different types of hinges to talk about them all, but I have chosen a few of the common ones that I see. I have 2 pictures of some common hinges, here and here. One common question is how do I get the oven door off or back on. Most hinges can be put into two different categories, ones that stay on the range and ones that come off with the door.
Some range doors can be opened to the broil position and then lift up on the door to remove the door from the hinges. Many gas ranges are like this and a lot of theelectric ones have gone this route as well. One of the most common hinge in the one that comes off with the door.
One of the most common hinge is this one.....To remove the door, open the door to the broil position. Don't use the handle to remove the door, grab hold of the door itself. Lift slightly and with your hands pull out on the door...the lifting gets the hinges out of the keepers and pulling out will dislodge the door hinges from there holders. This picture should help you out. Manual clean doors are easier to remove than self clean doors because sometimes a metal clip is added to the hold the hinge in place on the self clean doors. The screw and bracket have to be removed to remove the door and hinges. The metal clip bracket has to be reinstalled once the door is put back on. To reinstall the common hinge, just do the opposite, start the hinge blade in the receiver, lift slightly on the door and with your knees push the door and hinges back into place.
At our shop, I get at least one phone call a week on these hinges. GE ,viking and Frigidaire are two major manufactures that use these hinges. Some of the newer GE,viking oven doors can be lifted off and the hinges will stay on the range and most of the Frigidaire oven door hinges come off with the door. One thing most people forget about these hinges is that there is a clip that must be moved to hold the upper (A) and lower (B) parts of the hinge together. Once the door is put back on, the clip must be put back in the rest position. To reinstall the door, put the door at a 80degree angle to the range front, push in the larger upper hinge parts first and then lower in the smaller hinge parts, push the clips forward into the rest position and close the door.
On this style of hinge, one common problem is the hinge will sometimes "pop" forward against the range instead of staying still while you reinstall the door onto the hinges. If this happens, use a screw driver at the marked spot to help hold thehinge open so you can start the door onto the hinge, them remove the screwdriver to finish installing the door.
You will need to replace the door fittings.if the door is cracked then the door itself.
Hello Larry D Harris - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Do the maintop burners work? Granting that it does, you can try confirming that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. If after the basic troubleshooting, you continue to experience the issue I would suggest contacting a certified technician to assist in the full diagnosis and repair of your range.
I will need to order parts for both the hinge and the latching mechanism. The stove is an ULTRALINE RANGE Model: CVDSC485-6GBUBR Model Number: RO3150204933, eight burners with grill. Burners are gas, ovens are electric. Where do I order these parts ?
Also, I have had a long standing problem with the hood. The lights will not work, even when I install new transformers. The hood information is below.
Thanks for anything you can do to help.
Hood Model:
Best by Broan
Model PK22 Revision 'A'
Best @ 1-800-567-4689 Parts
General #: 1-800-463-2566
Hood transformer:
Model T 544012/A
Part #: B02300670
Pot. 40VA
Pri. 0 - 120 V 60Hz Marrone-Blu
Sec : 0-12 V Giallo-Rosso
1852/05/02/C Made in Italy
My information is:
Serial Number: RO3150204933
This is a Broan transformer from their Best line Discontinued. the Broan Part # is B02300670 Phone 18005581711 . I hope this helps it took me months of looking to find it.
