SOURCE: my oven and stove top in inoperative. the clock,
If everything checks out fine, and you have no wires grounding out, then the issue is the control or circuit board( same thing).
SOURCE: Hi, I need to find
Hello. Generally, the best local source for LP gas valves is your LP gas provider, give them a call. Also, there are several other sources including http://www.kitchenstuff.com/items.asp?Cc=HS1077, and local plumbing supply houses. J.
It has been a while, and I don't know if you still need help, but... On the 7000, the gas distribution rail is a square pipe. Get some gasket material and a couple of aluminum or steel bars, maybe two inches long by a half by an eighth, and something to clamp them onto the pipe. Cover all five holes with the bars and gasket and clamp in place.
If you have the old valve, it can be rebuilt; contact Repco in Texas (www.erepco.com) for pricing and details. Repco may also have some of that valve available for sale; they buy valve cores and bodies, and may have a rebuilt one already available. You're looking for the Heartland part number 7194.
Oh -- and as always, when working with gas, use soapy water to check for leaks. Don't check for leaks with a match; a leak too small to feel or hear will release enough gas to make an explosion. Remember that the gas jet on a stove burner is basically a pinhole.
