KitchenAid KHMS145KSS Microwave Oven Logo
Anonymous Posted on Jun 09, 2013
Safe to Use with Loud Rattling Sound?
My microwave works but has a loud rattling sound. Is it safe to keep using it? I do not use it often and would hope to not have to pay $360 for Kitchen Aid to come out and fix!
William Miller
Level 3:
  • KitchenAid Master 9,179 Answers
  • Posted on Jun 10, 2013
William Miller
KitchenAid Master
Level 3:
Answers
9179
Questions
Helped
4481555
Points
21747
It's not a good idea to continue to use it when it's making an unusual noise.
It may be arcing, which can lead to further failure or a fire, or it may be a defective stirrer or fan ,which can lead to uneven cooking or further failure.
$360 for a service call? Are you in Alaska or on Mars? That's insane. Maybe you can contact another servicer in your area?
Testimonial: "Yes, crazy cost!! It is for them to come out and then it includes a one year warranty. I will definitely just get the company that is coming out next time, on my own! Had called around first. Service calls in Mn are $85 EACH time they have to come--so $170, at the least, then plus the part. This $360 is through Kitchen Aid. If it can't be fixed, I get my money back. It is pretty much built in to my custom cabinets. I looked around with no luck of finding another that would fit without remodeling the cabinet area, which would also be expensive :( Tired of looking and calling, I guess, and just decided to pay up... Thank you for your reply. I appreciate it!"
5 Related Answers
Anonymous
  • 13 Answers
  • Posted on Jan 02, 2009
SOURCE: Kitchenaide Microwave KHMS145KSS rattling noise
there is a possibility that sme of the wireing or the fan has become loose best checking it .
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jan 03, 2009
SOURCE: Rattling Fan Noise
If I had to bet, I would say the fan blade assembly is loose on the fan motor shaft.
If so, a spot of super glue where they meet will usually take care of that.
If that's not it, it should be investigated.
It is vital that the cooling fan runs properly, or the magnetron will be destroyed.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
After you look into this, if you still need help, please write back with more details.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Aug 04, 2009
SOURCE: Burned out bulb on Kitchen Aid Microwave Model KBMC140
You will need to remove the oven from the wall and remove the outer cover.
If for some reason you don't have yours, you can download your owner's manual and installation instructions free from this page.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
These models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
You should be able to get one from a home center or local appliance parts store.
If you order it online (from the link above) it is part # 4375348.
hmlee390
  • 736 Answers
  • Posted on Oct 04, 2009
SOURCE: Rattling coming from top grill on Kitchenaid microwave
the gril at the top (above the door) usually comes off with a couple of screws or just pulls off .. on some you have to take the cabinet apart ..... inside you might find a flat filter put in at a slant .. its often a grease and smell filter that contains activated charcoal .. when it gets clogged then it can rattle around as air tries to get around it .. you can replace it or just leave it out ..
Anonymous
  • 8909 Answers
  • Posted on Jan 03, 2011
SOURCE: The power is on to my Kitchen Aid microwave
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Why is my Panasonic microwave making alot of rattling loud sound Is it dangerous
check the glass plate at the bottom of the microwave is sitting on the turning mechanism properly.
Microwave makes noise when on
All microwaves make some noise when running. Cooling fans, exhaust fans, turntable motor, transformer, and magnetron all make noise. I assume you mean some unusual noise. I need to know more about what kind of noise it is - a loud roar, a rattling sound, a high-pitch squealing sound, a "clunk-clunk" sound or what? By the way, a "klunk-klunk" sound is frequently caused by small debris stuck to the wheels of the turntable support tray. Try cleaning those wheels and the track they roll in.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Safe to use a microwave that is making a loud rattling sound?
1helpful
Loud rattling when operating
it could be a bad fan or a bad stirrer inside the wave guide. I would suggest you get a qualified technician to come check it out.
Makes a loud roaring sound when it is turned on. Is it safe to use?
I would say it wasn't and the magnetron or HV Diode requires attention.
Hope that helps.
When starting to reheat a loud crack, explosion, sound occurred,
As long as the door latches correctly there should be no danger. Some items will cause loud "explosions" in a microwave, such as whole potatoes when the skin has not been pierced. If the food contains pickling spices for example, the seeds will explode with a very loud sound like a gun.
As long as the oven continues to heat, there may be no other problem. But I suggest you stay near the unit when using it. Watch for smoke and be alert for strange odors. You don't mention the age of your oven but if it is new you can call GE customer care at 800 432 2737.
Ray
MICROWAVE SHUTS OFF WITHIN 3 SECONDS
you would need to open it and change the fuse if that don't work call the company for a hand book that should help.
Constant rattling noise during operation
possibly the "stirrer" motor - this is in the top and turns a metal reflecting ring to disperse the microwaves around the oven more evenly. About $70 on GE site for my oven.
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
