Question about Fitbit Zip Wireless Fitness Tracker
My fixbit changes at 12 noon instead of 12 midnight. how can I change that?
Why does the date on my seiko sne881 change at 12 noon?
probably because you have it set to 12 pm midnight and not 12 noon so at 12 noon it is actually midnight when the date will change
reset the time of the day to am or pm and any pm settings will change the date at 12 midnight.
Aug 30, 2015 | Seiko Watches
Date change
Hi.
I take it that your watch changes date at 12 noon, instead of 12 midnight.
If so change the time of your watch 12 hours, so it reads the same time, but instead of am, it is pm, or visa versa. Analog watches do not have a 24 hour time setting.
Jan 30, 2014 | Tissot Watches
Hi, My watch is changing date at 12 noon instead
Your watch is 12 hours out of step. (The date changes every second revolution of the hour hand.)
Wind your watch forward 12 hours, (you may have to reset the date) and it will then change around midnight.
Jun 07, 2011 | Hamilton X-Wind H77646733 Wrist Watch
My analog Guess watch has a date display only (no day). I have re-set the date over and over, but it changes the date at noon instead of at midnight.
Your problem is caused by the fact that the watch is 12 hours out of step.
Wind your watch forward 12 hours, reset the date if you need to and you watch will then change around midnight.
(if you need to change the date more than one day, when it has past the change time, wind it back and then forward to step the date forward. You may have to experiment to see how far past the change point (in both directions).
Jun 04, 2011 | Guess G85675G WristwWatch
My Emporio Armani 5330 has a problem in that the date advances at noon instead of at midnight so the 24 hour indicator on the bottom of the face is not in sync. How do I correct this?
Simply advance hands 12 hours forwards (clockwise). Just pull out crown to the time setting position and turn the watch hands forwards if the date is changing before midnight. If the date is changing after midnight - turn the hands 12 hours backwards. Don't do this when the actual time is between 10pm - 2am.
Jun 02, 2011 | Giorgio Armani Armani Bracelet watch...
My timex watch changes the date at noon instead of midnight. How do I fix this?
This is because you have reversed am with pm.
Set your watch 12 hours back and the problem should be solved.
You might want to wait till midnight or noon to check it's fine.
Note: if you see the day shows the previous day rather than the present day, you have to set the clock 24h ahead.
Problem solved!
Mar 02, 2011 | Timex Automatic Watch
I can't get the date on my F1 right. I set it, but it wants to change at noon or something. I can only make it right half the day. what do I do?
The date change occcurs at 12 O'clock but your watch is set so that it changes at 12 noon rather than 12 midnight. This is easy to correct, simply wind your watch on 12 hours and it will change at midnight.
Feb 16, 2011 | Tag Heuer Formula One
My calendar is switching 12 noon instead of midnight. i just bought this watch model 2600058 yesterday. how to adjust it>
I would turn the watch hands 12 hours then you will be at the correct spot for the 12 Noon and 12 Midnight times.... At this point you may need to change the date again also
Oct 11, 2010 | Movado 800 Performance watch
Day date changes midday 12:00 PM, not midnight 12:00 AM. How to change this?
Your watch thinks your noon is midnight.
Wind the hands forward 12 hours and the date change will be at midnight. You will have to re-set the date if it gains a day when doing this.
May 28, 2010 | Bulova Watch
Fitbit Zip Wireless Fitness Tracker Logo
261 people viewed this question
Top Fitbit Home Security Experts
Andrew Taylor
Andrew Taylor
robert
ray gallant
ray gallant
Are you a Fitbit Home Security Expert? Answer questions, earn points and help others
