Wont start with key,but when i jump the solenoid it starts but wont stay running,as soon as i let go of the solenoid it cuts off
SOURCE: won't stay running 95 jeep grand cheerekee laredo 4x4
When you put the jumper cables on, put the key in the drivers door lock and unlock the door to deactivate the factory alarm.
SOURCE: 95 F150 wont crank
the starter should be replaced. The solenoid is kikcing the pinion out but there is no contact being made to turn the starter motor. I have the exact same truck and before i changed the starter used the old starter tap trick. Tap the starter casing with a hammer and it should start turning again. hope this was helpful for you. Good luck.
SOURCE: starter stays enegaged on 1990 mustang gt
sounds like solenoid is shorted to ground internally
SOURCE: For Ford F-150 P/U 351 EFI, 1988, ignition problem
unfortuneately there is no shortcuts....But if there was for sure I'd tell you...it's really not hard....just take off the panelling on the lower and you can sneak it in and out...get back to me...I'M HERE TO HELP!!
Testimonial: "hey everybody these answers are on the money...., everyone should get this type of service from their auto service center thank you for your help jame"
SOURCE: As soon as my 2002 explorer starts it dies. After
ford has problem with idle air control valve
try to start the car next time and keep your foot on the gas pedal lightly
if it does not cut off then that's the problem
