Cameras Logo
A
Anonymous Posted on Jun 08, 2013
Canon powershot a2400 is memory card error
Memory card locked
CameraR
Level 3:
  • Cameras Master 4,738 Answers
  • Posted on Jun 10, 2013
CameraR
Cameras Master
Level 3:
Answers
4738
Questions
Helped
1195963
Points
12483
This video provides troubleshooting steps for memory card error.
5 Related Answers
Anonymous
  • 89 Answers
  • Posted on Nov 26, 2008
SOURCE: Hi. My Canon Powershot sd400
Hi!
You have to unlock your memory card. All memory cards have this small lock mechanism on the side.
Make sure that the slider is on the UNLOCK position. If it's already on the UNLOCK position and you are still getting the same error message, try to set it to LOCK, then set it back to UNLOCK position.
I hope that helps.
Good luck and have a nice day!
Anonymous
  • 3 Answers
  • Posted on Jan 28, 2009
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
Anonymous
  • 79 Answers
  • Posted on Apr 26, 2009
SOURCE: Memory card error - can't format card
Can you use the card in another device? Can you access the card un a USB card reader? If so, it is possible that the camera cannot handle a card that big. You would need to check the manual to see that it can handle a 4Gb card.
Anonymous
  • 51 Answers
  • Posted on May 20, 2009
SOURCE: Camera reading memory card error, cannot get it to work. Tried removeing the card and replacing batteries. Checked and it is not locked.
try formatting the card once on a pc and then plug it in your camera....if that does not help either, you'll have to try a different card.
Anonymous
  • 11967 Answers
  • Posted on Oct 21, 2009
SOURCE: Canon powershot SD1200 IS says Memory Card Error
You probably just need to format the card in the camera. This will completely erase it so download any pictures you want to save first.
Memory card error message on a canon powershot A700
On an SD card there is a switch at the side which can be moved to protect the card contents (locked) or permit writing to the card (unlocked). Just move this to the unlocked position.
Memory card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
MEMORY ERROR on the screen even
Keep in mind tha compabilitie memory card for this camera. Try formating your memory card.
9helpful
Canon powershot A480 gives error card locked
Hello! You need to take out the memory card of the camera. there is a small switch on the memory card's side 'locked- unlocked' Switch it to 'unlocked'.
I know this should work! please rate me 4 thumbs up if I helped you! :)
2helpful
4helpful
3answers
Sd card error on canon powershot s3
I get a memory card error everytime I insert a memory card. They are not locked and I have tried 4 different memory cards and nothing works. How can this problem be fixed?
2answers
Memory Card
b32f20a.jpgPowerShot SD630
Camera will not power on with a memory card installed.
1. Try another memory card and contact the memory card manufacturer 2. The PowerShot SD630 requires repair service.
This information sourced from Canon Support Forum page here
2answers
Canon Camera - Memory Card error & Card locked error
Try reading the card independent of a camera i.e. on a computer or a photo kiosk to determine if the card is readable damaged
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
